Oil Pressure gauge ?????????
Old Aug 10, 2004 | 10:23 AM
Drag-Accord's Avatar
Default Oil Pressure gauge ?????????
how would i install an mechanical oil pressure guage on my JDM H22a without having to drill into the block??
thanks guys
Old Aug 10, 2004 | 11:09 AM
Sack Master's Avatar
Default Re: Oil Pressure gauge ????????? (93BoostedAcclude)
Tee off the oil pressure sending unit. I'm not sure of the thread sizes though.
Old Aug 10, 2004 | 11:17 AM
deSigi's Avatar
Default Re: Oil Pressure gauge ????????? (Sack Master)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sack Master &raquo;</TD></TR><TR><TD CLASS="quote">Tee off the oil pressure sending unit. I'm not sure of the thread sizes though.</TD></TR></TABLE>
Yup
The engine block thread is 1/8 BSPT (British Standard Pipe Threading) and the oil pressure gauge will most likely be 1/8 NPT (National Pipe Threading....I think).
So you'll need an adapter going from BSPT male to NPT female, an NPT tee (make sure you put it on the firewall, not directly on the block), and an adapter from NPT male to BSPT female (this will be for the oil pressure sending unit that was initially in the block).
There was a company online that had everything you would need.....I forget the name. Mc...something, some help me out if you know.
EDIT: https://honda-tech.com/zerothread?id=785451
Old Aug 11, 2004 | 07:36 AM
Default Re: Oil Pressure gauge ????????? (deSigi)
thanks guys. i just went off of the back of the block. and NO LEAKS!!! gauge works great... but i saw the pic of what you explained. i'm most likely end up doing that with the braided line, when i get some spare time to do it.
anyways thanks' for your help
Old Aug 11, 2004 | 08:13 AM
deSigi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93BoostedAcclude &raquo;</TD></TR><TR><TD CLASS="quote">thanks guys. i just went off of the back of the block. and NO LEAKS!!! gauge works great... but i saw the pic of what you explained. i'm most likely end up doing that with the braided line, when i get some spare time to do it.
anyways thanks' for your help</TD></TR></TABLE>
That's a really good idea, because 4-cyl engines produce a lot of vibrations and there is a possibility that whatever you have hooked up to the block might break off wiith the vibrations. That's why it is suggested to hook the tee to the firewall.
torqueless
Apr 19, 2007 03:29 AM
danny_civic97
Mar 12, 2007 01:00 PM
n0pinitr0us
21
Apr 10, 2005 08:55 PM
2khb
Mar 30, 2005 03:20 PM
SOHCD16y8
Mar 26, 2004 05:04 PM
