Idle surge, tryed everything...HELP!!!!!!!!
Old Aug 14, 2004 | 08:39 AM
ITSTOCK's Avatar
Default Idle surge, tryed everything...HELP!!!!!!!!
I got a gsr swap in my 93 civic and it has a pretty bad idle surge from like 700 rpms to 1500 rpms. I tried messing with the TPS, IACV and fast idle valve, checked for vacuum leaks and everything and it still does it. Im completeley lost on what to check now. Anyone have any ideas? it doesnt have an o2 sensor, but i have a uberdata chip with it removed.
Old Aug 14, 2004 | 08:45 AM
mmuller's Avatar
Mad Scientist
Default Re: Idle surge, tryed everything...HELP!!!!!!!! (ITSTOCK)
does it do it all the time or only when cold?
have you checked your fitv?
Old Aug 14, 2004 | 09:03 AM
ITSTOCK's Avatar
Default Re: Idle surge, tryed everything...HELP!!!!!!!! (mmuller)
it does it constantly, what is the FITV?
Old Aug 15, 2004 | 08:38 AM
jmcclell's Avatar
You most likely have an air leak somewhere in the inlet.
Your IACV is shutting completely to try and compensate, then letting go, which causes the "pulsing idle". Disconnect the IACV and the car should stay at a constant high idle speed. If it does then its an air leak somewhere for definite. Usually its a leaky gasket or disconnected/split vacuum line somewhere.
Hope this helps.
To check your fast idle valve: With the IACV disconnected and the engine warm, put your finger over the hole (there are two of them) inside the throttle body that feeds the fast idle valve and see if the revs drop to normal. If this is the case, then you have a faulty fast idle valve.
Old Aug 26, 2004 | 10:53 AM
ITSTOCK's Avatar
Default Re: Idle surge, tryed everything...HELP!!!!!!!! (jmcclell)
i tried cleaning the IACV.... still surges
did the FITV adjustment still surges, when i disconnect the IACV and plug the 2 holes it just has a really rough stumbly idle like the iacv is diconnected, so it wasnt that,and i cant seem to find any vacuum or air leaks,so i am still confused.
Old Aug 26, 2004 | 06:41 PM
mmuller's Avatar
Mad Scientist
do you have an aftermarket tb?
Old Aug 26, 2004 | 07:55 PM
IVI's Avatar
IVI
i need help too im having the same problem.
Old Aug 26, 2004 | 10:10 PM
ITSTOCK's Avatar
Default Re: Idle surge, tryed everything...HELP!!!!!!!! (IVI)
when i spray starting fluid around the area where the throttle spring is it bogs it down really bad, could air be leaking into there causing the surge?
Old Aug 29, 2004 | 06:48 AM
99lspwr's Avatar
Please nobody help this kid until he starts giving peoples money back to those he has been ripping off over the past couple of years..Thanks
Old Aug 29, 2004 | 08:23 AM
IVI's Avatar
IVI
Default Re: Idle surge, tryed everything...HELP!!!!!!!! (99lspwr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99lspwr &raquo;</TD></TR><TR><TD CLASS="quote">Please nobody help this kid until he starts giving peoples money back to those he has been ripping off over the past couple of years..Thanks</TD></TR></TABLE>
i dont think your talkign about me.. but i need help on this.
Old Aug 29, 2004 | 04:32 PM
99lspwr's Avatar
No not you (IVI). Jaime, (itstock)...Thats who I am talking about....
Old Oct 28, 2004 | 12:03 PM
Pariah's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITSTOCK &raquo;</TD></TR><TR><TD CLASS="quote">when i spray starting fluid around the area where the throttle spring is it bogs it down really bad, could air be leaking into there causing the surge?</TD></TR></TABLE>
burn in hell theif.
KidDxbOrI
Jan 14, 2014 04:29 PM
Zatzy
Apr 16, 2006 10:57 PM
ick
Sep 11, 2005 10:46 PM
Cuong-nutz
Nov 25, 2004 10:34 AM
91SE
Feb 18, 2003 04:35 PM
