Donut gasket leaking problem.........
Old Aug 13, 2004 | 05:28 AM
Phatch99's Avatar
Default Donut gasket leaking problem.........
Does anybody know the part # for the correct donut gasket for a 4-1 header w/ 2.5 collector and 2.5 cat back exhaust? I bought one for a 94 ls teg it snugs in the header collector perfect but on the test pipe which i did custom 2.5 at a muffler shop it doesn't snug in to good and now it's leaking and i can here it every time i get up on it throughout the gears. does anybody here know what part # i can use without it leaking at all? i don't remember the part # for the one it got but it's for all 94+ tegs but inner dia. needs to be 2.5. Thanks for your help guys.
Old Aug 13, 2004 | 07:25 AM
Padawan's Avatar
Darth ModerVader
Default Re: Donut gasket leaking problem......... (Phatch99)
First, the gasket is meant to fit around the outside of the collector, not inside. You need a 2.5" ID gasket, and you have a few choices. You can contact SMSP and have him send you one (probably the least expensive route), or you can buy an OEM gasket from either Honda or Acura.
Honda: 18299 PCX 003 - S2000 gasket
Acura: 18229 SPO J51 - Legend gasket
Old Aug 13, 2004 | 10:35 AM
Phatch99's Avatar
Default Re: Donut gasket leaking problem......... (Padawan)
so either one will work? i'll just go to honda and get the cheapest one. what yr model on both cars?
Old Aug 13, 2004 | 10:49 AM
Padawan's Avatar
Darth ModerVader
I'm not sure about the Legend model years, but any year S2000 will work.
710dabber
Dec 4, 2015 09:51 AM
gldndrgn14
12
Mar 9, 2006 05:40 PM
Phatch99
Sep 8, 2005 01:16 PM
pwrdbyhonda
Oct 11, 2004 05:32 AM
