How hard is it to change a steering rack with hand tools?
Old Aug 9, 2004 | 10:18 PM
90da4dr's Avatar
Loved
Default How hard is it to change a steering rack with hand tools?
I took my car to a mechanic today because I get knocking sounds from the rack when I hit bumps. He checked it out and told me it was my rack. This is the second mechanic that has said this.
Thanks
Old Aug 9, 2004 | 10:20 PM
Sack Master's Avatar
Default Re: How hard is it to change a steering rack with hand tools? (95civ4dr)
I always used air but it only takes about 20 minutes both ways on a non-power steering 88-91 civic rack with no engine in it. Make sure you line the steering rack up with the steering column. I made that mistake once and ended up ripping the column out to get it all together. Not fun.
Old Aug 9, 2004 | 11:34 PM
michael O's Avatar
Default Re: How hard is it to change a steering rack with hand tools? (Sack Master)
I changed it in my garage with handtools. There was no engine in the car at the time and I completely forget how long it took. However it wasn't very hard to do at all.
Old Aug 10, 2004 | 01:19 PM
Agent Zero's Avatar
I have a question refering to this topic. My 94' HB is doing the same thing. (knocking sounds when going over bumps) What causes this? and what will happen if I dont fix it right away? Also does the motor have to come out to replace the steering rack? TIA
Old Aug 10, 2004 | 08:57 PM
ludacole's Avatar
Default Re: How hard is it to change a steering rack with hand tools? (redsihatchback)
good question, i got the knock too
Old Aug 10, 2004 | 09:18 PM
Default Re: How hard is it to change a steering rack with hand tools? (ludacole)
I have no clue how hard it would be to replace it with the engine in. My buddy changed over to non p/s in his coupe with the engine in but have no clue what he did to do it. As for the knock sound its probably a bad bushing or loose suspension part of some sort.
Old Aug 10, 2004 | 09:30 PM
Agent Zero's Avatar
Thanks for the info, but what part of the suspension and what bushing. I am not too familair with the steering column of my hatch. Do you know how to find out what is wrong.(how do you troubleshoot it) Is there a way to tell if it is bushing or suspension? TIA
Old Aug 10, 2004 | 09:45 PM
First place to start looking is at your upper A arm or lower control arm. If you don't know what you are looking at or working on take it to a shop that does stuff like that.
Old Aug 10, 2004 | 09:47 PM
mmuller's Avatar
Mad Scientist
my car was clunking when i went over bumps and it was a loose sway bar endlink
Old Aug 10, 2004 | 10:22 PM
Agent Zero's Avatar
Default Re: How hard is it to change a steering rack with hand tools? (mmuller)
One thing that I notice is that my steering wheel moves up and down a little. I haven't had a chance to take it off yet but it is a aftermarket wheel. My control arms are skunk2. (brand new) Where is the sway bar endlink? I am unfamilair with that part of the suspension. TIA
Old Aug 11, 2004 | 10:53 AM
ludacole's Avatar
yah mine clicks when the steering wheel is cranked all the way left what up with that
VTEC junky
Suspension & Brakes
May 26, 2013 10:48 AM
itsnotfast
Nov 23, 2009 02:34 PM
dr_latino999
Jun 17, 2008 09:59 AM
na4now
Feb 7, 2006 10:46 AM
CivicHB93JDM
Sep 8, 2005 09:00 AM
