Strange 3 bar mapsensor problem
Old Feb 15, 2007 | 03:53 AM
Importracer_001's Avatar
Default Strange 3 bar mapsensor problem
whats up guys,
I've got a problem with my car/S300 I started the car and was driving around a little and suddenly the car shut off and wouldn't start, there was a strong smell of fuel so I set the ignition on ON and started datalogging and when I tried to start the car the map trace goes completely to the 28 psi boost collumn instead of the vacuum collumns
I double checked my 3 bar mapsensor wiring and it shows me the correct values
I checked the ground continuity and that was good
checked to see if there is 5v on the C pin
and checked the voltage at the B pin which showed me 1.6v
According to http://www.hondata.com/tech3barmap.html my mapsensor is correctly wired.
WHat do you guys suggest?
Is there a way that i can test out the sensor itself?
Old Feb 16, 2007 | 10:39 AM
Iceman05's Avatar
u sure its a 3-bar? mine did the same thing and the sensor ended up being a 5-bar....
Freemananana
Engine Management and Tuning
12
Oct 16, 2013 02:41 AM
eg:R
Dec 21, 2006 03:14 PM
alexsracing
Jul 28, 2006 03:22 PM
MiKeAhOwSkI
Oct 25, 2004 06:03 PM
Cyphear
May 28, 2004 12:34 AM
