Need help please. OBd1 ecu problems!
Old Feb 10, 2007 | 03:15 AM
fin781's Avatar
Default Need help please. OBd1 ecu problems!
i have a 90 crx si (Obd0) and i have an Obd0 to Obd1 conversion harness, anyways we chipped the Obd1 ecu last night and got to chips burned, and the guy helping me said i would need an Obd1 distributor too, so i took the one off this d16y7 i have in my room and the plugs were different, so i had to put the stock Obd0 distributor back on.. so do i have to change the distributor or not, if so what has to be done ? repin the plugs to fit the Obd1 distributor ??? thanks in advance if anyone can help.
Old Feb 10, 2007 | 11:32 AM
Blown90hatcH's Avatar
Default Re: Need help please. OBd1 ecu problems! (fin781)
Yes, you have the run the OBD1 or OBD2 distributor. The trigger wheel tooth count is different from the pre-obd (OBD0). Just repin the plugs. There are a million threads on here about changing the plugs/wires.
7rrivera7
May 14, 2014 03:25 AM
carlthecrx
May 13, 2008 02:08 PM
ej8
Jan 27, 2005 10:56 PM
highvelocitynyc
Aug 17, 2003 10:17 PM
Bontke
Jun 1, 2003 09:51 AM
