Code 21 and 22 HELP!!! searched!!!
Old Feb 12, 2007 | 10:48 AM
Dat1BVtecN's Avatar
Default Code 21 and 22 HELP!!! searched!!!
Just put my motor back in my car, and threw code 21. Reseted the ECU and code 21 was gone but then 22 came on. CHecked all wiring and everything is good. Took off vtec solenoid and checked the screen everything was clean. Reseted the ECU again and 21 came back and 22 is gone, HELP!!!!
Old Feb 12, 2007 | 11:21 AM
Dat1BVtecN's Avatar
Default Re: Code 21 and 22 HELP!!! searched!!! (Dat1BVtecN)
bumpo
Old Feb 12, 2007 | 12:59 PM
Dat1BVtecN's Avatar
bump
Old Feb 12, 2007 | 01:27 PM
Dat1BVtecN's Avatar
boo boo
Old Feb 12, 2007 | 06:43 PM
Dat1BVtecN's Avatar
bump!
Old Feb 13, 2007 | 07:30 PM
Dat1BVtecN's Avatar
bump
Old Feb 13, 2007 | 08:07 PM
egsleepercivic's Avatar
more info
what car/ model?
was it working before you took out the motor?
Old Feb 13, 2007 | 08:44 PM
Dat1BVtecN's Avatar
Default Re: (egsleepercivic)
yes was working before, took out motor, 95 OBD1 GSR motor, 98 Acura Integra GS chassis
Old Feb 14, 2007 | 07:41 PM
clinicmotorsports's Avatar
pretty sure 21 is Vtec solenoid valve and 22 is the vtec pressure valve
https://honda-tech.com/zerothread?id=682412
Old Feb 16, 2007 | 02:32 PM
if everything was working before, I would redo the wire connections, if they are not soldered solder them and cover with heat shrink, also check your oil level
gl
JDMTRSPORTS
Feb 17, 2006 02:02 PM
SOHC_MShue
16
Apr 30, 2005 12:58 PM
xerox445
Apr 25, 2004 03:55 PM
hybridhatch18
10
Apr 19, 2004 08:26 AM
Fuster_Cluck
May 15, 2003 10:05 AM
