timing belt tension
Old Feb 15, 2007 | 11:48 PM
JDMtype Eg6's Avatar
Default timing belt tension
i have been noticing something weird concerning with the tension of my timing belt. everytime i check the tension of it, by pressing it with my finger i feel a noticable difference. sometimes the belt would be tight, sometimes loose, sometimes the front will be loose and the back would be tight, visa versa. any advice or suggestions would be apreciated, thanks.
Old Feb 16, 2007 | 12:09 PM
gents97civ's Avatar
It will depend on the temperature. The belt will tighten up as the engine warms up. You should be able to feel some play in the belt.
Old Feb 17, 2007 | 04:40 PM
thanks
Old Feb 18, 2007 | 05:45 AM
rmcdaniels's Avatar
Default Re: timing belt tension (JDMtype Eg6)
Probably a long shot, but I've had them stretch unevenly before. If that happens then you will see the belt "jumping" around a lot if you rev the motor when warm.
dleccord
Apr 13, 2020 08:03 AM
airikkCRX
Apr 2, 2010 08:29 AM
slide inside
Oct 22, 2009 09:25 AM
