tranny question
Old Feb 19, 2007 | 08:54 AM
crashzerothree's Avatar
Default tranny question
I have a hydro jdm gsr tranny with stock lsd that has a bad third gear grind, i just bought a hyrdo B16 tranny without lsd. what do i have to do to put the gsr lsd into the b16 tranny??? I know i need some feeler gauges, but what are the clearance specs??
Old Feb 19, 2007 | 04:13 PM
PHDZINE's Avatar
Default Re: tranny question (crashzerothree)
I believe the bolt pattern for the B16 differential is different than the GSR differential. So you wouldn't be able to just swap the differential out because the ring gears aren't interchangable. You would have to change both the ring and pinion gear to use the GSR LSD differential in a B16 tranny. The B16 and the LS have the same bolt pattern on the differential but different gearing...a little confusing!
blu00Si
Transmission & Drivetrain
Oct 11, 2013 05:15 AM
Alexpbnj
11
Sep 21, 2010 12:27 PM
TurboCivic11
Dec 22, 2009 05:51 PM
Spoon84
Jun 18, 2009 10:22 AM
NickQ
Oct 17, 2006 05:38 AM
