B16A Intake Manifold on B18C GSR
Old Feb 16, 2007 | 12:56 PM
AP1_man's Avatar
Default B16A Intake Manifold on B18C GSR???
Is it possible to put a B16A intake maniold on a GSR motor??? If so how hard to install???
Old Feb 16, 2007 | 01:28 PM
ekb16's Avatar
i dont think you can because b16 and GSR has a diff. mounting holes
Old Feb 17, 2007 | 02:17 PM
stockbee's Avatar
no you can't.
as ekb16 mentioned they have different mounting holes.
the B16a and the ITR manifolds are the same as far as they will fit on the same stuff but the GSR's are different.
Old Feb 17, 2007 | 03:12 PM
b16nonoy's Avatar
Default Re: B16A Intake Manifold on B18C GSR??? (teggy_si)
cant...different mounting holes.
Old Feb 17, 2007 | 04:22 PM
AP1_man's Avatar
so only way really if just using a b16 or b18c5 head
Old Feb 17, 2007 | 04:35 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (teggy_si)
There are aftermarket options, i.e. Skunk2.
Old Feb 17, 2007 | 06:18 PM
AP1_man's Avatar
i know...but from research and reading i did...alot (if not all) of after market intake manifolds are based on the Type R manifold=shorter runners than b16a. From dyno charts and what i read was the the b16a intake manifold is some what better for power band from about 4300rpms to 7600rpms, as the Type R is 7600rpms to 8500rpms. I am looknig for a manifold the will help in acceleration like the b16a...I am wondering if there is something close to it that would show the same results in power band.
Old Feb 21, 2007 | 08:24 AM
stockbee's Avatar
there are obviously better explanations to this, and praise be to whoever does it better than me but...... our motors make power in the top end anyway, unless you have aftermarket cams that make better midrange and what not you don't need a different stock intake manifold on your GSR motor, especially one that won't fit. Getting an aftermarket one will look better, perhaps pull less in the midrange (without a tune especially), and pull harder up top due to the design.
Old Feb 24, 2007 | 11:58 PM
who cares's Avatar
if you have a b18c1 the ports are nothing like a type-r or a b16a. although if you have a b17a they will inter change.
as for the aftermarket obx is a good bang for the buck $150.00
88 EF Hatch
11
Nov 27, 2008 06:48 PM
peter-ek4
Apr 11, 2008 05:05 AM
b17rider
Apr 5, 2008 09:09 AM
enhancedCL9
Oct 8, 2002 07:50 AM
