TPS or Vacuum Leak?
Old Feb 19, 2007 | 12:42 AM
EG9_808's Avatar
Default TPS or Vacuum Leak?
Every morning I warm up my car for about 3 mins and go to class. Once I park my car on campus and put it into drive my idle jumps from 1500 to 700 continuously until I turn off the car. Than after class I start up the car and the problem is gone until the next day.
Ive cleaned my IACV but still doesnt work. So Im guessing it could be my TPS not getting the proper voltage or a vacuum leak. True or false?
Thanks in advance
Old Feb 19, 2007 | 07:00 PM
EG9_808's Avatar
Default Re: TPS or Vacuum Leak? (EG9_808)
ok checked the voltage on the TPS, its reading at .50V!...wtf is the problem
Old Feb 21, 2007 | 06:57 PM
:Andrew's Avatar
do you have a FITV?
Old Feb 22, 2007 | 11:37 AM
njn63's Avatar
i'd check all the vacuum hoses for leaks.
Old Feb 22, 2007 | 11:41 AM
SuzukaBlueAP2's Avatar
Default Re: TPS or Vacuum Leak? (njn63)
what is the TPS voltage at WOT? I think it should be 4.45volts.
Is it only supposed to be .5 at idle? I don't recall.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by njn63 &raquo;</TD></TR><TR><TD CLASS="quote">i'd check all the vacuum hoses for leaks.</TD></TR></TABLE>
Always a good idea.
Old Feb 28, 2007 | 07:31 PM
:Andrew's Avatar
Default Re: TPS or Vacuum Leak? (SuzukaBlueAP2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuzukaBlueAP2 &raquo;</TD></TR><TR><TD CLASS="quote">what is the TPS voltage at WOT? I think it should be 4.45volts.
Always a good idea.</TD></TR></TABLE>
WOT= wide open throttle. It should be 4.5v according to Helms. And .05v at idle
Old Feb 28, 2007 | 08:37 PM
Default Re: TPS or Vacuum Leak? (:Andrew)
Thanks, cheif. I think we all know what WOT stands for...
As for voltage at idle, .05 seems a bit low. 5-hundreths of a volt is barely there.
I'm pretty certain 0.45 or 0.5 is what is normal for idle. If the car doesn't idle properly with a voltage in that range, the issue is somewhere else. Most likely a vacuum source.
Old Feb 28, 2007 | 09:12 PM
:Andrew's Avatar
my bad i thought you asked what it stood for. and yeah .5 typo. dont be a smartass
Old Mar 2, 2007 | 11:23 AM
EG9_808's Avatar
the voltage is right on the dot at idle and WOT.
so I started up my car this morning with the AC on and everything seems to run fine I let it run for about 5 mins and I turned OFF my AC and my idle starts to jump from 1500 to 700 continuously then i turned ON my AC and my idle was fine.
Any solution to this?
lude98SH
Mar 16, 2006 12:56 PM
prelude00sh
Apr 7, 2005 02:08 PM
94sohcEx
Sep 23, 2004 12:25 PM
Bigjussin
Mar 3, 2004 07:06 PM
ferio 95
Jan 21, 2004 03:39 PM
