Buying Built Car - Need advice
Old Feb 13, 2007 | 05:42 PM
iheartintegras's Avatar
Default Buying Built Car - Need advice
I'm looking to buy a fully built integra. I'd just like to know some tips as to what to look for if anything were wrong with it. I have had a turbo car before and I know what I'm getting into by buying this car. I'd just like to have extra reassurance in buying a car that isn't about to blow up. Thanks!
Here's the mods:
**HEAD
•DFE Enterprises port & polished head
•Ferrea Lightweight Race valves (1mm oversize intake)
•Bronze custom valve guides (shortened & tapered)
•Crower Super Heavy Duty valvesprings
•Crower Retainers
•Crower Titanium Valves
•Adjustable Rocker Arms
Crower 62404 camshafts
Brand new OEM seals/gaskets
JG Edelbrock Victor X Intake Manifold
Skunk2 adj. cam gears
ARP head studs
**BLOCK
Golden Eagle 2.0L
•Arias Pistons (9:1 comp)
•Eagle Rods
•Eagle Big Rod Bolts
•Step decked, O-ringed, line bored, bored and honed
•LS Crank
•ACL Bearings
•Blueprinted and balanced
Golden Eagle headgasket
Fluidyne half size, dual core radiator
12” slim fan
Avid Racing motor mounts
Brand new OEM belts and gaskets:
•Timing belt, water pump, oil pump
•Tensioner, intake manifold gasket, valve cover gasket
1. TURBO
Garrett GT3582R
Custom MSPi Top Mount Manifold
Custom MSPi 3" downpipe
Custom LHT 3.5" exhaust w/ butterfly valve
Earl’s SS oil feed/return/coolant lines
HKS SSQV BOV
Custom 2.75” charge piping
Hybrid Intercooler
Tial 44mm wastegate w/ 1bar spring
DRIVETRAIN
JDM GSR transmission
Kaaz 1.5 way LSD
Competition Clutch - Stage 5 (upgraded PP)
Skunk2 short shifter
Skunk2 shift ****
FUEL
Walbro 255lph HP fuel pump
Precision 1000cc injectors
Aeromotive inline fuel filter
Golden Eagle Fuel Rail
B&M adjustable FPR
Earl’s SS fuel lines
ENGINE MANAGEMENT/ELECTRONICS
Crome EMS
GM 3 bar map sensor
OBD2 to OBD1 conv. harness
Greddy Turbo Timer
Greddy Profec-B Spec II boost controller
Autometer Gauges – Cobalt series
MSD 6AL Ignition control
MSD SS Blaster Coil
MSD Distributor cap (Brand New) w/ new OEM ignitor
MSD Wires
Modified by iheartintegras at 8:32 PM 2/13/2007
Old Feb 13, 2007 | 06:38 PM
boostedblkef's Avatar
Default Re: Buying Built Car - Need advice (iheartintegras)
receipts for all parts and labor
who tuned it
ask to fully check it out by you if you know how or a mechanic who does if they say no or come up with a lame excuse there probably a reason
ask a ton of questions if they dont answer them or dont know WALK AWAY
hope i helped
Old Feb 13, 2007 | 07:08 PM
thanks.
How should I go about 'fully checking it out'?
Old Feb 13, 2007 | 07:25 PM
Car was built and tuned by Main Stream Performance Inc. in atlanta, ga
Here's a link to the for sale ad
Link to the build up thread
Old Feb 13, 2007 | 07:38 PM
Default Re: (iheartintegras)
well it seems like a pretty thourough build up check for his vouches on honda tech other than that just use good judgement it looks nice good luck hope its all good and you have fun with it
Old Feb 13, 2007 | 09:55 PM
gotcha, I'll bring my compression gauge with me when I go to look at it. Thanks for all the help
Old Feb 14, 2007 | 05:21 AM
sharkytm's Avatar
I'd have HIM start it up, and take it for a shakedown run, check the AFR's and see how he drives it.
neonkid
Nov 4, 2014 01:14 PM
integracura
Aug 22, 2007 05:25 PM
VtecKiDD
Jun 9, 2006 06:51 AM
19sec beast
Feb 25, 2006 01:51 PM
ferio 95
Oct 16, 2005 09:54 PM
