Gauge cluster HELP!!!
Old Apr 18, 2007 | 02:56 PM
jdmsi22's Avatar
Default Gauge cluster HELP!!!
I have a 99 si and when I got the car it had a white gauge face in it and I preferred the stock one. So I I took everything apart and a few minutes later I was where I could remove the face. Then I realized the needles were in the way. (DUH) So like an idiot I broke the base of the water temp needle from where it mounts in. I was hoping that it would snap back in but the tiny rod that goes into the cluster broke off. I was wondering what I could do to fix this. Or a way I could get around without the gauge functioning.
Old Apr 18, 2007 | 03:16 PM
illaborate978's Avatar
Default Re: Gauge cluster HELP!!! (jdmsi22)
you need to replace the whole gauge. go to a junkyard , clusters are sometimes hard to find there but you can remove whatever gauge you need seperately. might have to replace it with a gauge from a dx or ex cause i garantee there will be no si clusters there
f575gtc
Honda Civic (2001 - 2005)
Jan 16, 2015 01:48 PM
WH0R3nEF9
Mar 28, 2005 06:50 PM
NsX_CrX
Feb 11, 2005 10:12 PM
