d16a6 head on d15b8
Old Apr 15, 2007 | 08:57 AM
89efhatchy's Avatar
Default d16a6 head on d15b8
Can I put a d16a6 head on a d15b8? 16v head on an 8v motor, will everything work out right? Same head gasket? same timing belt?
Old Apr 16, 2007 | 12:43 PM
89efhatchy's Avatar
Default Re: d16a6 head on d15b8 (89efhatchy)
Someone on d-series.org answered my question
Old Apr 16, 2007 | 01:54 PM
civical4dr's Avatar
im not sure but once i put d16 vtec head on non vtec d serries block and when vtec crossedover valves hit pistons so be carefull
Old Apr 27, 2007 | 06:32 AM
blackhbkid's Avatar
Default Re: d16a6 head on d15b8 (civical4dr)
the 16 valve engines have 16 valve pistons, with 4 little gruves in them, So the valve dosnt hit the piston. 8 valve engines(d15b8) has 8 valve pistons, with only 2 little gruves in them so if you put the a6 or b7 head on you will have 8 valves hitting your piston
Old Apr 27, 2007 | 07:51 AM
Bense's Avatar
not all of the d15b8's have 8valve pistons. Most of them have 16v pistons. 4 reliefs per piston.
Old Apr 27, 2007 | 08:59 AM
slomofo's Avatar
GDD Member
I did the 16V swap on my POS D15B8, ran an LS ECU to 10krpm, Y8 intake manifold, B18B Throttle body, and Y8 Transmission..... it was pretty quick until the valves fell out.
Old Apr 27, 2007 | 09:05 AM
blackhbkid's Avatar
is there anyway to tell what kind of pistons you have withoot taking off your head?
Old Apr 27, 2007 | 09:19 AM
slomofo's Avatar
GDD Member
Default Re: (blackhbkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackhbkid &raquo;</TD></TR><TR><TD CLASS="quote">is there anyway to tell what kind of pistons you have withoot taking off your head?</TD></TR></TABLE>
Yeah, there is, just ask the guy who put them in.
Old Apr 27, 2007 | 09:24 AM
blackhbkid's Avatar
well the motor has never been touched can the dealership tell me?
Old Apr 27, 2007 | 09:29 AM
slomofo's Avatar
GDD Member
What's your vin number?
Old Apr 29, 2007 | 09:40 AM
blackhbkid's Avatar
how can you tell from the vin? I would rather not throw me vin number out there
Old Apr 29, 2007 | 08:17 PM
blackhbkid's Avatar
so then if you have a obd-1 d15b8 motor from a cx and you are trying to put a obd-0 head on what do you all have to change or do your use your same dizzy and ecu?
Spawne32
Dec 21, 2010 08:47 PM
pinks11
10
Mar 16, 2009 03:52 AM
Project_EK
Feb 2, 2009 09:23 AM
gas saver 08
Jun 23, 2008 05:56 PM
Slow89HB
Sep 30, 2003 06:13 PM
