b16 idle problem
Old Apr 16, 2007 | 03:10 AM
cbabyby's Avatar
Default b16 idle problem
i have a 93 civic ex with a jdm b16.... i just got done rebuilding my motor.... it starts and runs fine but idles between 2000 and 3000 rpms.... it was throwing a iacv code but i replaced it with a brand new one and didnt fix anything.... i unhooked my map sensor.... and the car still runs..... not sure but the last time i done this the car dieid instantly.... im sure this is something really stupid that im overlooking but i am running out of ideas...... motor ran and idled right when i took it out.....please help
Old Apr 16, 2007 | 04:32 AM
hondamanwill's Avatar
Did you buy mistake swap the IAC plug with the Air temp sensor plug easy to do.
Old Apr 16, 2007 | 06:16 AM
LSVTEC426's Avatar
Default Re: (hondamanwill)
Im actually having pretty much the same idle problem. It will idle at 2g then drop down to a g and keep doing the same thing. I think my problem is theres a vac spot on the back of the intake mani where there should be a vac line but im not sure where it goes. Anyone know where that goes on a b16? I think it ties into the line going into the fuel rail
Old Apr 16, 2007 | 06:23 AM
GSR_Hatch12's Avatar
Default Re: (LSVTEC426)
could be a problem with the lower wax element on the bottom of the throttle body. Take your intake off when the car is running and use your finger to plug each one of the holes on the side of it. Do that one at a time and which ever hole you plug changes your idle that's what is wrong unles there is a large vacum leak.
Top hole is for the rear IAC valve on the back
Bottem hole is for the wax element on the bottom of throttle body.
Old Apr 16, 2007 | 03:30 PM
allnaturalb16's Avatar
Default Re: (GSR_Hatch12)
The problem is one of two things vaccuum leak (probably off of the black catch can on the back of the block) or tps
Old Apr 17, 2007 | 05:54 PM
cbabyby's Avatar
Default Re: (allnaturalb16)
i will try all of these suggestions tomorrow... i dont think my plugs are mixed up because.... i had to extend the original ex harness... and i havent had any problems until now.... i was gonna replace the tps.... just to see if it helped.... i also sourced that from a junkyard originally...... but those holes i am supposed to cover where are those located at again.....
Old Apr 19, 2007 | 04:44 PM
cbabyby's Avatar
Default Re: (cbabyby)
i just stuck my finger over the hole in the throttle body....it lowered my idle like 200 rpms.... nothing worth bragging about...... i also just checked my codes im throwing 10 and 3..... 10 is intake air temp.... i replaced my intake gasket with a spacer.... has thrown this code ever since..... and 3 map sensor...... i can unhook my map sensor and the car still runs..... not sure how but it does...... does anyone know if this can cause the car to idle to high?????
jarvis199
Sep 15, 2005 06:26 PM
CrRexSiR
25
Mar 29, 2004 05:46 PM
