I hit my launch control while driving...
Old Apr 17, 2007 | 05:27 PM
dustin_crxsi's Avatar
Default I hit my launch control while driving...
I cant drive go past 3200 rpm's. I thought it had to somehting with timing. It happens in different grears, but never 1st. Mainly 3rd.
wtf?
Old Apr 17, 2007 | 05:49 PM
NJIN BUILDR's Avatar
Default Re: I hit my launch control while driving... (dustin_crxsi)
It shouldn't work once your moving.You may have reset your rev limiter but most likely you disconnected the cable from the ecu to the blue box.I'm assuming Hondata.Is the red led in the box blinking?
Old Apr 17, 2007 | 05:51 PM
Default Re: I hit my launch control while driving... (NJIN BUILDR)
sorry, i should have specified.
its a PW0 using Crome Pro
Old Apr 17, 2007 | 06:25 PM
Should I disconnect the power over night.. let it reset?
Old Apr 17, 2007 | 07:03 PM
Yep...still wondering what I should do.
Old Apr 17, 2007 | 07:28 PM
93supercoupe's Avatar
un plug and see if it comes back.
is there a check engine light on?
Old Apr 17, 2007 | 07:37 PM
Default Re: I hit my launch control while driving... (93supercoupe)
nope. no lights
Old Apr 17, 2007 | 07:39 PM
if u cant burn ur own chips, then have some one that can make u one.
If its not the distro, then its most likely the chip.
Old Apr 17, 2007 | 07:43 PM
Could it possibly be the sparkplugs? when I took the head off, and put the valve springs in..i left the sparkplugs in. Its getting spark. I kow this for sure
Old Apr 17, 2007 | 09:19 PM
vss sensor?
the cable kinda goes up and down. some play in it.. maybe the wire behinda the guage cluster?
Old Apr 18, 2007 | 07:31 AM
2k.civic.si's Avatar
launch control in crome works off the vss....since your cable driven i would check the wiring coming off the back of the gauge cluster
Old Apr 18, 2007 | 07:36 AM
Default Re: I hit my launch control while driving... (2k.civic.si)
Its a blue wire...correct?
Old Apr 18, 2007 | 11:43 AM
Big Bang's Avatar
no blue wire is tach. just snug up the screws that are on the back of the cluster right behind the speedo and that should fix it. Had a similar problem in my CRX but i just didn't get Vtec
Old Apr 18, 2007 | 04:13 PM
projectjazzmine's Avatar
Default Re: I hit my launch control while driving... (The Converted)
not trying to jack the thread but I have the same problem with my 94 ls-t. Was running fine for two weeks now it sputters (sounds like a silenced machine gun) when I accelerate. But I'm tuned with Uberdata. Could I have the same problem?
thanks in advance,
Rajuy
Old Apr 18, 2007 | 05:50 PM
Big Bang's Avatar
Default Re: I hit my launch control while driving... (projectjazzmine)
your car has an electric speedo so as long as your gauge woks that's not the problem. I don't knwow hat the weather has been like down there but if it got warmer or anything like that right before the problem came up i'd start lookin at your tune.
Smoked95
Jun 4, 2015 05:51 PM
tuthpick
Jul 28, 2014 08:27 PM
JONESn'
Feb 15, 2013 01:21 PM
EusebioSam19
14
Oct 6, 2011 08:49 PM
