obd-1 or obd-2 please help!!!!!
Old Apr 18, 2007 | 02:41 PM
ALLMOTOR CRX's Avatar
Default obd-1 or obd-2 please help!!!!!
i need to get my car to pass smog but i have a 99 gsr motor in it and im running it as obd-1 i want to converted it to obd-2 to pass state ref would it be hard? im running all sensor and parts from the 99 gsr motor.. the only think i would need is the obd-0 to obd-2a hopper,second 02 sensor how would i wire that?, anything else i need for it to pass state referee?... oh and one more thing which is better obd-1 or obd-2 ecu?
Old Apr 18, 2007 | 03:04 PM
illaborate978's Avatar
Default Re: obd-1 or obd-2 please help!!!!! (ALLMOTOR CRX)
obd2 is suposed to be only good for passing inspection. obd1 is better for sport. i dont see why your failing with an obd2 setup. has to be something else.
Old Apr 18, 2007 | 03:48 PM
so you are saying that obd-2 is easier to pass emessions test? you sure about that? i mean obd-2 ecu are pretty hard cored if you dont have something hooked they will let you know by throwing out the check engine light... and if thats on you wont pass state ref.... going back to my questions can anybody help me out... how would i wire up the second o2 sensor?
Old Apr 18, 2007 | 05:03 PM
bump
Old Apr 19, 2007 | 08:50 AM
any info on this?"
Old Apr 19, 2007 | 10:38 AM
HAMOTORSPORTS's Avatar
obd0 mpfi to obd2a jumper
obd2a p72 ecu
use helms to wire up second 02
make sure you are running a 4 wire primary o2
if going to referee you will also need an obd2 compliant cat.
Old Apr 19, 2007 | 06:49 PM
oh and i just read that you all obd-2 vehicles require to have the dlc diagnostic link connector.. to communicate with the machines there.. if it doesnt it does not pass.. im just going to try obd-1 ill will tell them the motor is a 95 gsr motor.. will be using the obd-1 gsr intake mani...
Old Apr 20, 2007 | 10:08 AM
if it is at the referee, he will look at the stamp on the head and see it isn't a 95. best of luck.
Old Apr 20, 2007 | 10:10 AM
you think so so? do you think he will pass me anyway or just attempt to pass me? i mean if i go in there im going in as obd-1 95 gsr motor...
Brugalontherocks
Apr 28, 2008 08:10 PM
strictly.business
May 29, 2006 09:24 AM
MeanGreenEG9
Dec 4, 2002 11:16 PM
iluznxpnoi
Mar 30, 2002 11:40 AM
