Need help with Timing
Old Apr 12, 2007 | 01:52 PM
Fasthtch's Avatar
Default Need help with Timing
I have a gsr engine and i got the head milled .20 over 3 angle valve job and intake manifold was port and polished to match. I did gsr base timing and it idols horrible like at 500 rpm and spark plugs keep getting fouled up Pleaser Help........
Old Apr 12, 2007 | 03:13 PM
NJcoupe's Avatar
Default Re: Need help with Timing (Fasthtch)
Gsr base timing; but what about fuel trim?
Old Apr 12, 2007 | 06:23 PM
Fasthtch's Avatar
Default Re: Need help with Timing (idriveacoupe.)
I havent messed with anythihng else but its running really rich theirs like straight black smoke coming out my exhaust ... should i try advancing the timing more b/c when i let of the gas rpms drop below 500 and the battery light pops up for a quick sec
Old Apr 13, 2007 | 06:55 AM
vtec4max's Avatar
that's when the adjustable cams comes in.
Old Apr 15, 2007 | 06:55 AM
kevinz's Avatar
Default Re: (vtec4max)
adjustable cam gears. you can advance the intake gear to help timing advance issues because head was milled,,,there is a formula out there somewere,,,
ek_life
May 22, 2015 06:39 PM
gofast300@gmail.com
Feb 6, 2009 07:00 AM
serious
Nov 25, 2002 10:29 AM
1.8Tities
Sep 8, 2002 03:32 AM
