LS-VTEC Dowel pins
Old Apr 20, 2007 | 11:40 AM
frstbte14's Avatar
Default LS-VTEC Dowel pins
If anyone would be so kind as to get me the exact dimensions of those pins, down to the thousandth of an inch, i can start making those. Hook a brotha up
Old Apr 20, 2007 | 12:23 PM
Exxel82's Avatar
Default Re: LS-VTEC Dowel pins (frstbte14)
I dont know the exact measurements, but I would just tell you to buy one from the dealership so that you always have one on hand for measuring. They are relatively inexpensive.
Old Apr 20, 2007 | 01:28 PM
EGhatch87's Avatar
i bought mine from full-race for $25
Old Apr 26, 2007 | 08:33 AM
frstbte14's Avatar
Anybody with a set and a micrometer/dial caliper on hand?
Old Apr 26, 2007 | 12:30 PM
Scarface1's Avatar
71.118.105.6
Buy a set from Honda and measure them yourself.
Old Apr 26, 2007 | 02:37 PM
BILLETGRIP's Avatar
Default Re: LS-VTEC Dowel pins (Scarface1)
i'd like to know to but im just gonna wait till i get the head and measure the dowel holes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Scarface1 &raquo;</TD></TR><TR><TD CLASS="quote">Buy a set from Honda and measure them yourself.</TD></TR></TABLE>
^^^^^^^^^^^^^mad cause he cant read a set of mics^^^^^^^^^^^^^
Old Apr 27, 2007 | 11:39 AM
frstbte14's Avatar
Default Re: LS-VTEC Dowel pins (BILLETGRIP)
thats what im trying to get around.... buying. i have a machine shop at hand and a lot of materials.
Old Apr 27, 2007 | 04:03 PM
BILLETGRIP's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by frstbte14 &raquo;</TD></TR><TR><TD CLASS="quote">thats what im trying to get around.... buying. i have a machine shop at hand and a lot of materials.</TD></TR></TABLE>
your gonna have to get a vtec head to do lsvtec. just measure the dowel holes on the head when you get it. or are you gonna try to make them for other people (as in production) with out actually goin lsvtec yourself? cuz if you are i would just say forget it. your gonna lose money trying to beat the prices of companies already makin them. i always make my own **** ( block girdle, block guard, cam gears, flanges) but i dont try to sell them. i just do it for the satisfaction of sayin "hey i made that".
Old Apr 30, 2007 | 11:37 AM
frstbte14's Avatar
Well most companies sell them at 25, I can do it local for 20. I recieve free materials, and work in the shop, so there is no lost wages nore cost for materials for me. I have a H-swap so theres no reason for me to get a vtec head or ls bottom to attempt this.
Old Apr 30, 2007 | 05:06 PM
BILLETGRIP's Avatar
what material are you gonna make them out of? does your shop have cnc lathes?
Old Apr 30, 2007 | 07:29 PM
indicajones's Avatar
ill get u the measurements by thursday at the very latest. i hav a micormeter. i have some laying around at the shop. was going to use them but decided to just do ls/vtec the old way. didnt like the using of a pr3 head gasket that sticks out way past the block. that whole ls/vtec conversion kit seems like a problem just waiting ot happen. so im sticking with the way it was invented. but ill definalty get u those measuremnts if ur trying ot make a few extra bucks on the side
Old May 1, 2007 | 11:49 AM
frstbte14's Avatar
Default Re: (indicajones)
not cnc lathes, but a lathe non the less. i can do everything with acupro and have it dead set on. i work exclusively with stainless and aluminum, so in order to keep the expansion rates based on heat, i will use aluminum.
Old May 1, 2007 | 02:00 PM
BILLETGRIP's Avatar
Default Re: (frstbte14)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by frstbte14 &raquo;</TD></TR><TR><TD CLASS="quote">so in order to keep the expansion rates based on heat, i will use aluminum.</TD></TR></TABLE>
im not tellin you what material to use, but have you seen the oem ones? they are far from aluminum. and i really dont think your gonna have to worry about expansion on something with a wall thickness of .030. i just made some to dowel my girdle to the mains out of 13mm O1 drill rod so that the critical dimension was already ground. we dont have lathes only cnc mills so that was the easist and quickest way i could think of.
Old May 2, 2007 | 08:08 AM
frstbte14's Avatar
Default Re: (BILLETGRIP)
Thats awesome, I wish we were fortunate enough to have CNC capabilities. We have quite a few machines, formost being the vertical mill and the lathe.
Old May 2, 2007 | 03:02 PM
BILLETGRIP's Avatar
i wish we had a cnc lathe or at least a manual lathe. you could machine those dowels and be done in about 20 seconds on a cnc lathe.
Old May 3, 2007 | 11:46 AM
frstbte14's Avatar
well i have a lathe, and thats what makes it easy for me to make them.
M0N0C4M
Jul 2, 2007 02:52 PM
MattZ28
May 3, 2007 11:07 AM
JDM JEFFREY
Sep 16, 2005 09:37 PM
JjuuN R
Dec 4, 2003 12:12 AM
Trak_Day
Sep 4, 2003 06:55 AM
