Hondata s300 Map Switch?
Old Apr 15, 2007 | 12:12 PM
EJ8 GSR-T's Avatar
Default Hondata s300 Map Switch?
I have a boosted civic (gsr motor) running hondata s300. I had it tuned awhile back with the stock map sensor so they tuned it to like 9.5 psi as the sensor wouldnt read much more. I am ready to move up to a GM 3bar and hopefully make some more power but i am curios about the tuning. Will the new map sensor require a new tune from scratch? I was told by my tuner than he would have to start from scratch but it seems like the s300 might have the ability to "recognize" a replacment sensor so would it be able to keep the tune? I wish i could word this better but hopefully you get the idea.
Old Apr 15, 2007 | 03:31 PM
EJ8 GSR-T's Avatar
Default Re: Hondata s300 Map Switch? (EJ8 GSR-T)
Someones gotta know
Old Apr 15, 2007 | 07:13 PM
Jim Truett's Avatar
Retune from scratch.
Old Apr 15, 2007 | 07:55 PM
EJ8 GSR-T's Avatar
Default Re: Hondata s300 Map Switch? (Jim Truett)
Damn, so that mean i have to have the shop install the sensor too as i cant drive it to my tuner with an incorrect tune
Old Apr 16, 2007 | 04:10 PM
EJ8 GSR-T's Avatar
Old Apr 16, 2007 | 07:53 PM
crxrocks's Avatar
You can swap the MAP sensor, adjust the config in SManager for the new sensor and then take it easy on the drive to your tuner. I wouldn't think you would need to start from scratch though.
Old Apr 17, 2007 | 08:51 AM
Spunkster's Avatar
Default Re: (crxrocks)
You should not have to start from scratch, but you may want to check your AF on the dyno just to make sure there are no problems.
Old Apr 17, 2007 | 09:09 AM
EJ8 GSR-T's Avatar
Default Re: (Spunkster)
Hmmm well that sounds hopeful. My tuner is about 50 miles from home, and i plan on swapping it out and driving it right over to be tuned for about 20psi so it will be retuned but its nice that i may be able to save an hour on the dyno if it dosnt have to be done from the ground up again.
Todallybuilt
Engine Management and Tuning
Oct 29, 2017 06:05 AM
GT500FTW
Apr 11, 2014 10:15 AM
Dave_yd
Mar 24, 2008 12:57 PM
lucidvtec
Jul 11, 2005 11:51 PM
boosted hybrid
May 31, 2003 09:30 AM
