is there any transmission for me?
Old Apr 17, 2007 | 09:12 AM
Swipe'd's Avatar
Default is there any transmission for me?
i got a 90 crx dx, i have a d16 motor and i want to stay oem...
is there any transmission that came with a lsd that will drop in my crx
i kno the vti was hydo so that wont werk in my crx... will it?
and i herd about a zc tranny that came with on? can ne1 confirm and is so wut 1?
thnx
greg
Old Apr 17, 2007 | 09:28 AM
Bense's Avatar
you'll spend more time, and more money trying to find a transmission that meets your needs than it would be to just build one.
it's not that hard.
the only 88-91 D-series LSD's that were available were the ZC LSDs which use the larger splines, so you'd need to get custom axles.
Your best bet is to contact hmotors and get a ZC trans and maybe look for one with an LSD. But even then, you'll have trouble finding the halfshaft + axles. Plus the 3.888 final drive sucks.
If you care about hybrid gearing, i'd get a ZC trans and drop a si final + si 5th in it. then use an OBX LSD.
Old Apr 17, 2007 | 10:20 AM
BlueCrxNC's Avatar
You already have the DX/Si/TegZXi 1-5 (all same)... you could just get a better final drive gear (Si, ZXi, aftermarket 4.7, 4.9) and an OBX LSD. Check my signature for my setup. If you can get a ZC tranny then that's great. Different final drive would definitely be a must IMO.
Old Apr 17, 2007 | 08:16 PM
Swipe'd's Avatar
well i herd that the obx lsd is crap, so i was gonna DEFF make my own tranny, but i want a lsd in it, SO
i wanted to budget and get a oem single cam lsd, than put it in a CRX Si hybrid with custom gearings n final drive...
^ is that possible and if so wut lsd n case n gears should i get n use?
Old Apr 17, 2007 | 08:47 PM
Swipe'd's Avatar
and is the obx lsd really a good thing, and which ones do i buy, i here there is like a new modle and an old model, and is it needed 2 rebuild them now a dayz?
Old Apr 18, 2007 | 03:02 AM
BlueCrxNC's Avatar
To get the best performance out of the LSD you'll need to take it apart and rearrange the Spring Washers for maximum preload. See here for information.
https://honda-tech.com/zerothread?id=1752849
https://honda-tech.com/zerothread?id=1714724
Old Apr 18, 2007 | 05:15 AM
Swipe'd's Avatar
o ok, i didnt kno y u were suppose 2 even strip n put together the lsd, that sounds good..
charlie_sohc
Feb 21, 2008 06:56 AM
johngrady
Jan 27, 2008 07:01 AM
EF9ZC
Mar 30, 2006 12:45 PM
Roadracejunkie
14
Apr 6, 2005 07:16 PM
