fuel and tuning
Old Apr 14, 2007 | 07:21 AM
meric0786's Avatar
Default fuel and tuning
ok i have a 94 jdm gsr with the skunk 2 intake manifold skunk2 65 mm throttle body aem fuel rail aem hybrid cold air intake buddy club spec 4 cams buddy club valves springs and retainers aem fuel regulator and skunk2 proseries cam gears also a full msd ignition(the box,coil dizzy) what size injectors should i run for this set up.
also i am runnig a chipped p 28 . my friend is telling me he can tune this computer using a lap top but i was also looking into a hondata system what do you guys recomend.
Old Apr 14, 2007 | 08:51 AM
meric0786's Avatar
Default Re: fuel and tuning (meric0786)
bump
Old Apr 14, 2007 | 09:03 AM
HAMOTORSPORTS's Avatar
310's to 370's depending on head porting/exhaust should be sufficient
Old Apr 14, 2007 | 05:47 PM
meric0786's Avatar
Default Re: (HAMOTORSPORTSUSA)
ok thanks
Old Apr 26, 2007 | 06:46 AM
HorseHunter's Avatar
Hey whats up man. I'm interested in the ls vtec motor you are selling in your other thread I just cant post there cause im new on hondatech. I was wondering if you would be able to give me some more information and a list of mods that are done to the motor? I got a 97 Integra and I blew my head gasket so I was lookin to get a new motor. I was gonna do a JDM Type-R swap but they are really expensive for a stock motor so I thought maybe I could find a hooked up one for the same price.
Old Apr 29, 2007 | 06:13 AM
meric0786's Avatar
Default Re: (HorseHunter)
this motor has everything you can imagine ls sleeved block bored to a2.0L cp 8.5-1 compression pistions corrilla rods comitic head gasket all bolts are arp eagle blueprinted and balanced crank skunk2 stage 2 turbo cams with proseris cam gears gready timing belt 3 angle valve job with a full skunk 2 head set up(springs retainers and valves) head is ported and polished also now has a port matched skunk2 intake manifold with type r throttle body this is a complete motor swap minus timing covers turbo setup and clutch like i said i have 2 trans to choose from gsr or ls both are just rebuilt and both have lsd
Old Apr 29, 2007 | 06:52 AM
Well I think i found a type-r engine for a fairly good price. I might be getting that one but if I end up not getting it then I will def give you a call. I can't message you back though because I don't have IM yet... still a noob, lol. I found a nice one from Japan for $4,000.
Old Apr 29, 2007 | 09:49 PM
doood's Avatar
been there done that
what would your friend tune with? if you have enough confidence in him not to blow up your engine, go at it.
b16nonoy
Mar 20, 2007 09:22 AM
Gatweb
23
Mar 9, 2005 06:39 PM
i v o u s
Jan 28, 2005 10:13 PM
Gatweb
Nov 5, 2004 10:09 AM
