ARP rod bolts torque specs??
Old Apr 12, 2007 | 01:16 PM
b20vtech's Avatar
Default ARP rod bolts torque specs??
i have a 5.394 LS eagle rod with the 5/16 arp rod bolts ....just want to know the torque spec on them..... thanks in advanced....
Modified by b20vtech at 10:39 AM 4/14/2007
Modified by b20vtech at 9:33 AM 4/20/2007
Old Apr 13, 2007 | 06:56 AM
vtec4max's Avatar
I believe its 40 lb ft.
Old Apr 13, 2007 | 10:01 AM
Scarface1's Avatar
71.118.105.6
Default Re: ARP rod bolts torque specs?? (b20vtech)
should have not thrown instructions away. Give APR a call
Old Apr 13, 2007 | 11:39 AM
b20vtech's Avatar
Default Re: ARP rod bolts torque specs?? (Scarface1)
bought it without the papers.... but anyone knows arp's number??
Old Apr 13, 2007 | 12:50 PM
b18bturbo's Avatar
go here call eaglerod.com
Old Apr 13, 2007 | 01:27 PM
Lubo_25's Avatar
beware of connecting rods without torque specs!!...but yea look for the arp part number...
Old Apr 14, 2007 | 08:35 AM
vtec4max's Avatar
I've got the same thing and it says on the box to torque it to 40 lb ft.
Old Apr 14, 2007 | 09:38 AM
b20vtech's Avatar
Default Re: (vtec4max)
ok, im stuck now, if it's a 3/8 rod bolt, then u use a 3/8 12point socket right??
i don't get the termonology of the 5/16 and 3/8 rod bolt.....
Old Apr 16, 2007 | 01:38 PM
Lubo_25's Avatar
Default Re: (b20vtech)
torque wrenches are not allowed on arp rod bolts...use at own discretion
Old Apr 16, 2007 | 04:30 PM
DonF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20vtech &raquo;</TD></TR><TR><TD CLASS="quote">ok, im stuck now, if it's a 3/8 rod bolt, then u use a 3/8 12point socket right??
i don't get the termonology of the 5/16 and 3/8 rod bolt.....</TD></TR></TABLE> Then do NOT assemble this yourself.
Old Apr 17, 2007 | 01:26 PM
b20vtech's Avatar
Default Re: (DonF)
i have built alot of motors before, but with stock rod combonation, so of course im gonna attemp to do this myself.....
Old Apr 17, 2007 | 01:37 PM
Legion's Avatar
* B A N N E D *
Please don't use a torque wrench on rod bolts
Old Apr 18, 2007 | 09:46 AM
b20vtech's Avatar
Default Re: (Semtec)
then what do i use???
Old Apr 18, 2007 | 12:33 PM
Lubo_25's Avatar
a nice bolt stretch gage with .001" increments...you can try to burrow one if you can get access or you can buy them from summt racing i believe they come with a 2 lb. spring so it wont slip off the bolt ends...
Old Apr 19, 2007 | 11:38 AM
b20vtech's Avatar
Default Re: (Lubo_25)
thanks alot
Old Apr 19, 2007 | 03:12 PM
Lubo_25's Avatar
you're welcome comrade
Old Apr 19, 2007 | 04:47 PM
b20vtech's Avatar
hey so u use a bolt stretch gauge to torque them down??? im confuse
Old Apr 19, 2007 | 05:03 PM
Echo7847's Avatar
Old Apr 19, 2007 | 05:41 PM
b20vtech's Avatar
Default Re: (Echo7847)
isn't that to measure it after torquing??? or u could actually use that thing to torque it?? still confuse
Old Apr 19, 2007 | 09:11 PM
Legion's Avatar
* B A N N E D *
Step 1: Use a torque wrench to tighten the bolts to something safe, like 35 ft-lbs.
Step 2: Use a ratchet or box wrench to continue tightening the bolts, in increments of about 1/16th of a turn. After each partial turn, put the gauge on the bolt and check how far it's stretched. If it hasn't stretched enough, remove the gauge and give the bolt another 1/16th of a turn.
Keep doing this until the bolt has stretched the appropriate amount. Be warned: the stretch increases exponentially as you approach the bolt's yeild strength. Translation: as you approach the correct stretch spec, you'll barely have to turn the bolt at all for it to continue stretching. I'm talking like 1/64th of a turn.
Old Apr 19, 2007 | 10:09 PM
gsrious's Avatar
^^ in response to the above... you dont have to take the gauge off all the time to stretch it. your using the box end of the wrench so just lift up the wrench, then repeat.
one question i do have though,...
since you stretched the rod bolt initialy, how are you going to measuring again we you do a tear down and rebuild again using the same rods? since they were stretched already, what are you suppose to do?
Old Apr 20, 2007 | 02:17 AM
Legion's Avatar
* B A N N E D *
Default Re: (gsrious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrious &raquo;</TD></TR><TR><TD CLASS="quote">^^ in response to the above... you dont have to take the gauge off all the time to stretch it. your using the box end of the wrench so just lift up the wrench, then repeat.</TD></TR></TABLE>
Easier said than done. Besides, for the most accurate results, I wouldn't rely on the gauge's spring pressure. I usually squeeze the ends together to make sure the pin is REALLY seated into the bolt dimple.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
since you stretched the rod bolt initialy, how are you going to measuring again we you do a tear down and rebuild again using the same rods? since they were stretched already, what are you suppose to do?</TD></TR></TABLE>
They don't stretch permanently - they only stretch when they are torqued. When you loosen them, they shrink back to their original length.
Old Apr 20, 2007 | 08:32 AM
b20vtech's Avatar
so whats stretch spec for the 5/16 arp rod bolt??
Old Apr 20, 2007 | 08:51 AM
Lubo_25's Avatar
arp should give you the stretch specs along with their relative torque...the stretch specs comes from their tensile testing equipment...email them your part number and they should get back to you if you dont have your spec sheet...good luck
CA6VTEC
Dec 12, 2005 10:17 PM
2phast
Jun 25, 2005 08:41 PM
nortrop
Aug 16, 2004 06:03 AM
H22coupe
Apr 9, 2004 01:44 AM
S13 slide
Jan 8, 2002 09:29 AM
