Need help will CEL code 10!
Old Apr 12, 2007 | 09:34 AM
Harddrnker's Avatar
Default Need help with CEL code 10!
I have a d16y8 swap into a obd1 dx. Im using a p28 ecu. The car starts but runs like crap. The CEL code its giving is 10. How do i fix this code on this swap. Any help will be great.
code 10 - IAT sensor
Old Apr 12, 2007 | 09:54 AM
NJcoupe's Avatar
Default Re: Need help with CEL code 10! (Harddrnker)
Do you have the IAT wired up? I highly doubt it cause your using an OBD2 motor with the IAT sensor that mounts in the intake arm; versus the OBD1 style harness that mounths the IAT in the intake manifold.
Old Apr 12, 2007 | 06:14 PM
Harddrnker's Avatar
Default Re: Need help with CEL code 10! (idriveacoupe.)
no its not hooked up
Old Apr 12, 2007 | 06:17 PM
Harddrnker's Avatar
So do i need to hook the obd1 IAT up some how?
Old Apr 13, 2007 | 09:39 AM
NJcoupe's Avatar
hook it up and let it hang there to get rid of your CEL for the moment. But the correct way to fix it would be to get the obd2 sensor and plug; which i have available if you need one.
Old Apr 14, 2007 | 11:25 AM
Harddrnker's Avatar
ok i hooked it up and now that codes gone but i have codes 19, and 22 and the car is running like **** and sounds like ****. When i go to give it gas it kinda stalls out. I dont know if the timing is off or what. Any ideas?
19- auto tanny lock up
22- V-tec
Old Apr 14, 2007 | 03:08 PM
Harddrnker's Avatar
TTT
Old Apr 15, 2007 | 11:07 AM
Harddrnker's Avatar
ok now the idle is all crazy. Its reving up and down at idle.
Old Apr 15, 2007 | 03:37 PM
Harddrnker's Avatar
anyone???
Old Apr 16, 2007 | 12:28 AM
Harddrnker's Avatar
back up
blackwagon
Nov 16, 2010 07:15 AM
PaChiLa Leader
Oct 10, 2005 04:45 AM
LoseRPunKx182
Aug 25, 2005 08:53 AM
-=TWITCH=-
Sep 20, 2004 07:52 PM
Flamenco-T
Sep 8, 2002 12:05 PM
