Need Help with A/C
Old Apr 13, 2007 | 08:27 AM
Chrisdotcom's Avatar
Default Need Help with A/C
I have a 1995 Civic Si and I recently tried to fix my ac i thought all it needed was freon but it turned out the condensor had a hole in it. So I went to put one in but it was out of a 1992 Civic Ex but then the lines wouldnt meet up...then I put different lines then the compressor didnt line up with the lines so I switched out the compressor then I went to put the main line on it wouldnt fit so I got the ends cut and welded with a different tip so it would screw together...it blew cold for about a week or two but now its hot air during the day and semi-cold at night. And the compressor shuts off and on and makes clicking sounds and the car runs stupidly. So now my main question is Im thinking about buying an A/C System off an Ek wich is the condensor,compressor, and the lines will everything bolt perfectly in my car. Id greatly appreciate the help thx.
Old Apr 13, 2007 | 11:29 AM
Default Re: Need Help with A/C (Chrisdotcom)
anyone? Know if the ac systems are the same.
JDMdoode
Honda Civic (2006 - 2015)
Sep 3, 2018 10:44 AM
akb427
Honda Civic (2001 - 2005)
Feb 25, 2013 02:21 AM
notnilc20
Jun 16, 2012 10:34 PM
solsi2000
Aug 24, 2009 06:30 PM
coot_er
Jul 22, 2004 01:59 PM
