GS-Rtranny reverse lockout problem?.
Old Apr 16, 2007 | 10:03 PM
Motul87's Avatar
Default GS-Rtranny reverse lockout problem?.
01' gsr tranny, 47,xxx miles
GM syhncro-mesh
ACT Xtreme PP
Skunk2 dual bend short shifter,Energy stabilizer bushings
when i first swapped in the tranny it was fine, every gear is smooth, reverse was SOMETIMES rough to get into but nothing major to take note of until recent. 2 days ago it just straight up will not let me into reverse at all... so i changed the tranny fluid with no results, im hoping its something stupid that one of you guys can point out to me, im going to put the stock stabilizer bushings back in and maybe try another set of shift linkage. if you need any more descriptions let me know...thanks in advance.
Old Apr 17, 2007 | 03:33 PM
Motul87's Avatar
Default Re: GS-Rtranny reverse lockout problem?. (Motul87)
bump
Old Apr 20, 2007 | 07:43 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
either the 5/R sleeve and hub has wear spurs on the hub slines or the selector mechanism tab that moves 5/R fork is bent. your problem most likely lies internally.
Fern413
Jul 6, 2009 10:12 AM
Kyles ej1
Jun 30, 2004 04:42 PM
yellowbuffalo
Jan 10, 2004 05:42 AM
