Wrist pin question/problem???
Old Apr 19, 2007 | 11:18 AM
eg6madness's Avatar
Default Wrist pin question/problem???
i took the pistons out of my GSR motor, the wrist pins were tight in the piston and the connecting rods. I got them pressed out and placed the rods on my new P30 pistons. the Wrist pins that came with the P30 (which are stock honda piston and pins) were fitting loose.
i took them to the machine shop and got the pins pressed in the P30 and stock rods the pins still fit loose in the pistons but they are tight in the rods (actually they dont move). they are pressed in very tight.
I want to kno if they are suppose to be like that?
will the heat expand them and make them fit tight in the piston as well?
if i put them in the block will the pins move under RPM and slap the cylinder walls?
Is there something that i am forgetting between the piston and pin?
Old Apr 19, 2007 | 05:12 PM
BILLETGRIP's Avatar
Default Re: Wrist pin question/problem??? (eg6madness)
the pin should press in the rod and slip in the piston. if your can actually feel slop between the pin and piston i wouldnt run them.
Old Apr 19, 2007 | 05:16 PM
eg6madness's Avatar
Default Re: Wrist pin question/problem??? (BILLETGRIP)
slop as in play?
there no play, but the pin goes in and out of the piston easily. there is some drag but it is not tight. The pins have been pressed into the rods, and are tight, no play no movement. but they sit in the piston still allowing some side to side movement.
Old Apr 20, 2007 | 04:42 PM
BILLETGRIP's Avatar
side to side movement is fine. if the pin was tight in the piston and the rod then it wouldnt pivot.
Old Apr 20, 2007 | 05:32 PM
eg6madness's Avatar
ok. well i guess i have nothing to worry about.
D-SOHC 05
Nov 16, 2007 05:20 AM
eg6madness
Apr 19, 2007 06:02 PM
eg6madness
Apr 12, 2007 03:55 AM
gaskleppie
Apr 14, 2004 09:34 AM
alfee
Mar 28, 2004 10:08 PM
