Cometic Head Gasket Leaking?
Old Apr 20, 2007 | 11:18 AM
B18C_EJ8's Avatar
Default Cometic Head Gasket Leaking?
I'll skip straight to the cliffs...
Shop installed new Cometic head gasket on my motor when they installed my freshly ported head. (Engine is 82mm B18C)
Shop also installed new Skunk2 Pro intake manifold & Hondata IM gasket.
Car is blowing white smoke on Dyno.
Shop now wants to pull head again.
Possible faulty Cometic gasket or something else???
Shop is an hour away so I can't see what's going on until probably tomorrow...
Ideas?
Old Apr 20, 2007 | 11:22 AM
HAMOTORSPORTS's Avatar
did they use an 82mm cometic gasket?? I've seen stock size head gaskets burn through when used on larger bores.
Old Apr 20, 2007 | 11:24 AM
B18C_EJ8's Avatar
I purchased the gasket and it was the 82mm bore.
Old Apr 20, 2007 | 11:27 AM
have the head pressure tested while off to make sure they didn't over port on the short turn radius and get into the water pockets in the head
Old Apr 20, 2007 | 11:30 AM
B18C_EJ8's Avatar
I highly doubt anything of that nature ocurred... I don't think that Endyn would make such a grave error.
Old Apr 20, 2007 | 12:24 PM
Golden Eagle's Avatar
Default Re: (B18C_EJ8)
cometic gaskets are known for failing that's why we cut oem gaskets
Old Apr 20, 2007 | 12:27 PM
B18C_EJ8's Avatar
Sonofabitch...
So much for driving my car this beautiful weekend...
Old Apr 20, 2007 | 12:28 PM
we do have 82mm in stock and can ship today
Old Apr 20, 2007 | 12:48 PM
B18C_EJ8's Avatar
PM'ed.
Old Apr 20, 2007 | 12:57 PM
replyed
Old Apr 21, 2007 | 05:32 AM
ITRnorway's Avatar
what kind of sleeves is in the block? cometic has two different design on there HG. where the one with thicker fire ring cant be used if the sleeve is above the deck of the block
Old Apr 21, 2007 | 05:34 AM
ITRnorway's Avatar
mr Golden Eagle: does youre sleevs sit flush with the block deck?
Old Apr 21, 2007 | 12:13 PM
inspyral's Avatar
Default Re: (ITRnorway)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITRnorway &raquo;</TD></TR><TR><TD CLASS="quote">mr Golden Eagle: does youre sleevs sit flush with the block deck?</TD></TR></TABLE>
GE sleeves are usually step-decked.
Old Apr 21, 2007 | 01:44 PM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITRnorway &raquo;</TD></TR><TR><TD CLASS="quote">what kind of sleeves is in the block? cometic has two different design on there HG. where the one with thicker fire ring cant be used if the sleeve is above the deck of the block</TD></TR></TABLE>
OEM sleeves.
Old Apr 25, 2007 | 07:32 AM
B18C_EJ8's Avatar
I guess I should have listened to people that said Cometic gaskets were crap...
Spoke to Cometic and the company I bought the gasket from, and neither one want to hear anything about this situation...
Cometic told me that since it's a performance part, there's no warranty, even though the damn thing didn't see any "performance" and it blew at idle....
:thumdown: to Cometic....
Edited to add that my first post said that it blew on the Dyno. Not the case. The car didn't even see the dyno and the gasket blew...
Old Apr 25, 2007 | 09:05 AM
there step decked, but that has nothing to do with cometic gaskets being junk
Cho0se
Feb 24, 2020 02:59 PM
abiliojr
Jun 3, 2015 11:09 PM
ntoxicatedtigah
Nov 26, 2008 10:47 AM
da_33
Jan 11, 2007 11:12 AM
flip1199
Oct 2, 2005 04:33 PM
