crx engine swap
you need everything from a 1990-1991 integra axles ecu and rear bracket and radiator hoses
then you need a hasport mount and shift linkage kit
then you have to cut off the front mount bracket off the crossmember and then bang away at the inner frame near the alternator for clearance issues
and i recommend getting a new clutch setup and doing a full tune up on it including new timing belt and oil/water pump
suburban_ninja
18
Nov 11, 2013 10:15 AM
giff74
May 27, 2004 01:24 AM
Search. its been covered. Oh and Just a warning....
