!!Having trouble with GE Scattershield install!!
Does anyone know where i can find pictures of an h series GE scattershield? for some reason its not fitting right on my h22. its hitting my clutch slave cylinder. and not sure where the bottom part of the shield should bolt up to (i know its one of the case bolts but dont know which one).
Thanks in advance
Thanks in advance
the bottom piece bolts to the rear most hole in the transmission, where the transmission and motor come together. if you lay it out you will be able to see.
ki11a8ee
Apr 14, 2007 07:01 AM
Civicpmp04
28
Jan 31, 2006 08:27 AM
