EF light wire harness
Old Feb 17, 2010 | 06:46 PM
rsa0905's Avatar
Default EF light wire harness
Im having problems with my EF and its lights. Im thinking it may be easier to find a donor harness for the lights, and just splice them in to get the old one out. Heres my problem; My brake lights stopped working, and when i press the brake pedal, the dash light for an open door comes on instead of my brake lights. Also, if i put my hazard lights on, instead of blinking through the corner lights, they blink through the highbeams on the headlights. I think this problem may be stemming from when the previous owner did a crappy job of putting HIDs in. I mean its a mess. So what im asking is could it be possible(and maybe easier) to take a donor harness and just splice it in around the dash to get rid of the mess with the HIDs?? Would this maybe fix the problem with all these lights working under different functions; hazards working through highbeams, and brake lights not working but when brake pedal is pushed a dash light comes on.
Old Feb 17, 2010 | 08:12 PM
SolAssassin's Avatar
Default Re: EF light wire harness
sounds like you bought the car from a ricer! get an entirely new engine and cabin harness from a donor car
Old Feb 18, 2010 | 07:18 AM
rsa0905's Avatar
Thats the thing, the swap was done okay, its just the lights are being stupid. Im gonna try getting a whole new harness for the lights after i try removing all non factory wiring.
Old Feb 18, 2010 | 07:20 AM
fcm's Avatar
fcm
Old Fart
The HIDs should not be wired to the dash harness, if it was, the previous was not a ricer, he was a dumbass.
With that said, I would check harness grounds, when diff. circuits have an effect on each other it is almost always because of a grounding issue. 94
Old Feb 18, 2010 | 10:52 AM
rsa0905's Avatar
Alright, thanks. Ill be checking everything out. Thanks for the help guys
Old Feb 18, 2010 | 01:45 PM
cpearson's Avatar
New User
Good luck man. Let us know how it turns out.
Old Feb 18, 2010 | 02:09 PM
rsa0905's Avatar
I got it figured out. For some reason the horn and the brake lights are on the same fuse. And when i hit the horn it blows the fuse, thus causing the brake lights to not work. I blew 2 20a fuses before putting a 30 in and it hasnt blown yet. Im still taking those shitty HIDs out though lol.
Old Feb 18, 2010 | 04:14 PM
fcm's Avatar
fcm
Old Fart
DO NOT replace fuses with bigger ones, it can lead to the car burning to the ground.
Find the problem and fix it, [probably a bad horn], unplug the horn(s) and install the proper fuse and press the horn button, if fuse does not blow the horn, [or one of them if you have two] is bad, replace it. 94
motoman32002
Nov 17, 2011 07:28 PM
90AcuraIntegra04
Jan 12, 2011 06:16 AM
toolbox21
Mar 17, 2009 08:31 PM
sadiusomega
Jul 27, 2005 08:43 PM
dc24me
Oct 18, 2004 07:29 PM
