Battery Light On New Swap.
Old Mar 10, 2010 | 08:33 AM
cerealbox575's Avatar
Default Battery Light On New Swap.
ok so me and my buddy ordered a b20 from hmo we put it in a eg and it start up with no check engine light. the battery light is the only light on. after running the car for a while the lights start to turn off. i put the hazards on and they blink really fast (like if a bulb was out but they are not) eventually the car dies and wont start back up. i was thinking the alternator? but its a fresh swap from hmo.
the car runs a little rough but we were gonna change the spark plugs and wires to see if it made a difference.
any help is appreciated TIA
Old Mar 10, 2010 | 02:37 PM
mouab18c1's Avatar
Default Re: Battery Light On New Swap.
Do your lights seem brighter than normal? Your alternator might be over charging your battery. The alternator will not test bad if you try the easy test by removing the positive connection to the battery. Had this happen to me, so i test it out at Schucks and the alternator failed everything. Alternator is your best luck or try a new battery.
Old Mar 10, 2010 | 02:39 PM
dumpster's Avatar
is the battery dead after the car dies?
Old Mar 10, 2010 | 06:34 PM
yes the battery is dead. but he didnt have any problems with the battery before the swap. i was thinking it might be a bad ground. there was a grounding kit on the single cam that was on there.
Old Mar 10, 2010 | 06:38 PM
mouab18c1's Avatar
Do what I said, take it out and get it tested.
Old Mar 11, 2010 | 07:20 PM
dumpster's Avatar
sounds like the alternator
Old Mar 11, 2010 | 08:00 PM
figured it out. turns out there was not belt on the alternator... DUHH!! lol
i didnt notice cuz i was night time when we got it started, then i went over today and was like "wow im dumb, theres NO BELT!"
onunezp
Jul 14, 2014 07:42 PM
tyvtec23
10
Feb 10, 2012 11:22 AM
busha61067
Feb 10, 2010 04:54 PM
korean_teg
Sep 30, 2005 08:27 PM
biggdogg
18
Nov 26, 2003 06:32 AM
