car shuts off while drivin. need help
alright i have a 89 crx si. daily driver, drive about everyday.
has b16a swap and has stage 3 clutch and 10lb flywheel.
while drivin it runs fine while in gear. then when i start to slow down like comin to stop light i push clutch to floor and car looses all rpms and just shuts off. but will start right back up everytime. it will run fine at idle and will drive fine if im up shifting or in gear. just shuts off when clutch is pushed all way down
any ideas as to what would cause this? need help thanks!
See if it happens when you push the clutch in without pressing the brake and if it happens when you just pop it out of gear without pressing the gas in the same situation.
figured it out.
took iac valve off and cleaned and it helped it
now i need a new one tho anyone have one?
and nah mike i dont have your number anymore man lost all my numbers
Dav94Lx
Feb 2, 2008 07:53 AM
rig9896
Sep 22, 2003 11:34 AM
