Will obd1 PR4 work with electronic VSS?
I'm working on a 93 DB1 that I got as a shell. It came with a dc gsr cluster that has the plugs properly converted and the electronic vss wires are tapped into the ecu wiring so it was working fine with the previous owner's setup. I picked up an electronic vss from a 92 accord so it also has the power steering lines.
I'm still in the process of getting this together. Do I need to start looking for an obd1 p75 ecu or will the pr4 not matter for how the vss works?
92-93 integra: obd1 PR4 ecu with cable operated vss
94-95 integra: obd1 P75 ecu with electronic vss
If you don't know what you are talking about, don't post.
909ej
Dec 31, 2010 09:11 PM
