Valve spring install/removal on VTEC head
Old Jun 4, 2005 | 08:39 AM
PogKai's Avatar
Default Valve spring install/removal on VTEC head
Some said that it's needed to take the head out to install/remove the valve springs on a VTEC head, but on a non-VTEC head removal isn't nesessary. Is it true?
Old Jun 4, 2005 | 09:01 AM
Chiovnidca's Avatar
Default Re: Valve spring install/removal on VTEC head (PogKai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PogKai &raquo;</TD></TR><TR><TD CLASS="quote"> Is it true?</TD></TR></TABLE>
Nope
Old Jun 4, 2005 | 02:29 PM
Toxidomask's Avatar
Default Re: Valve spring install/removal on VTEC head (Chiovnidca)
make it easier for your self. You do have to take that stuff out. especially the V-tec head. Because if you use the tool to press the springs ratainers and clips back in, you might just drop the damn valves in the piston, believe me its hard enough to compress those damn springs you would not want to worry about valves falling back in the chamber.
Old Jun 4, 2005 | 04:23 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Valve spring install/removal on VTEC head (Toxidomask)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Toxidomask &raquo;</TD></TR><TR><TD CLASS="quote">make it easier for your self. You do have to take that stuff out. especially the V-tec head. Because if you use the tool to press the springs ratainers and clips back in, you might just drop the damn valves in the piston, believe me its hard enough to compress those damn springs you would not want to worry about valves falling back in the chamber. </TD></TR></TABLE>
He could pressurize the cylinder or feed some nylon rope into the plug hole and move the piston up to hold the valves.
Old Jun 4, 2005 | 09:49 PM
PrettyLude's Avatar
you can use a leakdown tester to pressurize the chambers to hold the valves up
Mike@K-Tuned
17
Nov 19, 2006 01:00 PM
wahabum
Mar 9, 2006 08:01 AM
98lsskunk
Sep 24, 2005 07:36 PM
4rcefeddeceiver
Jan 4, 2004 07:37 PM
jabroni95gsr
Nov 19, 2002 08:17 AM
