running on 2 cylinders - need help
Old May 30, 2005 | 11:27 AM
SoOHiGH's Avatar
Default running on 2 cylinders - need help
eg w/ jdm h22a with a p13.
-getting spark from wires.
-got new spark plugs
-fuel injectors are good
-getting fuel (when i pull plugs they're wet)
-compression = all above 220
-Timing = cam gears, flywheel, and crank lines up at TDC
... and its running on cylinders #1 & #4 only. How do i know this? because i accidently touched the header and it wasnt hot. 1 & 4 is hot and 2 & 3 isnt.
btw i posted in prelude, civic, and hybrid forum and no one knows what the problem is.
Old May 30, 2005 | 11:41 AM
WestCoRacer's Avatar
Default Re: running on 2 cylinders - need help (SoOHiGH)
wires 2 and 3 are crossed
Old May 30, 2005 | 11:54 AM
SoOHiGH's Avatar
Default Re: running on 2 cylinders - need help (WestCoRacer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WestCoRacer &raquo;</TD></TR><TR><TD CLASS="quote">wires 2 and 3 are crossed</TD></TR></TABLE>
no they aint
34
12
and the valve cover ... 1 is on the driver side
Old May 30, 2005 | 12:06 PM
If you have compression, fuel and spark as you say, not much else can cause that to happen but the timing of the spark delivery.
Old May 30, 2005 | 12:07 PM
SoOHiGH's Avatar
would a bad dizzy cause this?
Old May 30, 2005 | 12:08 PM
1..3..4..2 going counterclockwise
If only 2 cylinders are firing, the engine must just barely run
Old May 30, 2005 | 12:10 PM
try swapping distribs with a friend
Old May 30, 2005 | 12:16 PM
SoOHiGH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WestCoRacer &raquo;</TD></TR><TR><TD CLASS="quote">1..3..4..2 going counterclockwise
If only 2 cylinders are firing, the engine must just barely run</TD></TR></TABLE>
1 3 4 2?
should it be liek this
34
12
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WestCoRacer &raquo;</TD></TR><TR><TD CLASS="quote">try swapping distribs with a friend</TD></TR></TABLE>
its a jdm h22 ... not that much people have a h22 internal dizzy.
im gonna get my cousins sohc si dizzy and swap the internals.
Old May 30, 2005 | 02:52 PM
SoOHiGH's Avatar
fix the problem ..... turned out to be a bad dizzy.
Sungsu
Mar 31, 2010 05:11 PM
ilandhopr
Oct 24, 2007 06:11 PM
SoOHiGH
May 30, 2005 02:53 PM
elwood
Jan 31, 2004 01:41 AM
SSBlueDC2
Feb 7, 2003 07:45 PM
