ebay cam gear any good?
Old Jun 3, 2005 | 06:54 PM
1boostedcivic's Avatar
Default ebay cam gear any good?
are they any good? the bolts are on the outside therefore they should be able to handle a great deal of torque. im on engine rebuild budget, and curious. this is going to be a boosted application.......
http://cgi.ebay.com/ebaymotors...33614
Old Jun 3, 2005 | 10:47 PM
EnzoSpeed's Avatar
Default Re: ebay cam gear any good? (1boostedcivic)
I wouldn't compromise something as important as cam timing by using that cam gear. You can seriously get a used AEM/Skunk2 cam gear on ebay for about $50-60 if you are patient.
Old Jun 4, 2005 | 06:08 AM
Default Re: ebay cam gear any good? (EnzoSpeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EnzoSpeed &raquo;</TD></TR><TR><TD CLASS="quote">I wouldn't compromise something as important as cam timing by using that cam gear. You can seriously get a used AEM/Skunk2 cam gear on ebay for about $50-60 if you are patient.</TD></TR></TABLE>
oh i can get the aem cam gear for that price. but due to the placement of the bolts alot of people say it gives them problems. So do u guys think i should go with aem or skunk 2 huh???
Old Jun 4, 2005 | 06:37 AM
b18blackek's Avatar
ahahah u gonna pay 40 bucks for a three screw cam gear? dats no good..
Old Jun 4, 2005 | 09:53 AM
v4lu3s's Avatar
RTFM
i would go with AEM or skunk2 but not those, go with something that uses a regular bolt rather than an allen bolt.
Old Jun 4, 2005 | 11:25 AM
rmcdaniels's Avatar
AEM and Skunk2 should be fine if you actually torque the screws to the manufacturers specs. I used Skunk2 and had no problems with the allen head bolts.
That said, buy the GE or the STR gears, the marks are much easier to read than they are on other gears. Skunk2 and AEM have tiny little marks that make it hard to see what you are setting it at.
I would avoid the no-name ebay gears, there's just too much downside if those things don't hold.
Old Jun 4, 2005 | 07:08 PM
PrettyLude's Avatar
i have some str 57 pro gears, looks pimp and works great
Skatnshawn
Nov 5, 2012 11:00 AM
casmello
Jan 6, 2005 04:41 AM
jweller
Jan 6, 2003 08:43 AM
