compression numbers need help
Old Jun 25, 2005 | 07:29 AM
Guru Designs's Avatar
* B A N N E D *
Default compression numbers need help
After finally getting a compression gauge i can further tech my motor to see whats the problem but i got some compression numbers and i dont know what to think of them.
Cylinder 1- 232 psi
cylinder 2- 228 psi
cylinder 3- 234 psi
cylinder 4- 224 psi
average psi in motor 230.
Is it normal to have a high and low with a diffrence of 10 psi's. thanks in advance for you help
Old Jun 25, 2005 | 07:39 AM
LSVTEC 91 Civic's Avatar
Banned
Yep, looks good to me. Did you have the ECU fuse out when you were doing the test? Was the motor warm?
Old Jun 25, 2005 | 07:53 AM
* B A N N E D *
no and no. i havent been able to start my car in about a week. i did disconnect the dizzy so that i wont blow the ignitor.
Old Jun 25, 2005 | 08:05 AM
Banned
Default Re: (tobe2be)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tobe2be &raquo;</TD></TR><TR><TD CLASS="quote">no and no. i havent been able to start my car in about a week. i did disconnect the dizzy so that i wont blow the ignitor.</TD></TR></TABLE>
Next time do it with the motor warm, and pull the ECU fuse out for a more accurate reading.
Old Jun 25, 2005 | 08:44 PM
D@nnY's Avatar
those numbers are fine
ntensehonda
Feb 5, 2009 10:34 PM
souljah_jon
Aug 29, 2007 10:16 PM
Amused
Oct 26, 2006 03:30 AM
2000civic-Si
12
Aug 29, 2005 11:47 AM
HatchBox
Aug 4, 2003 03:41 PM
