Car won't start
Old Jun 24, 2005 | 08:55 AM
UNKNOWN_MEMBER's Avatar
Default Car won't start
Motor used to start but threw code 15 so I swapped out ignitors then tried to start it. Nothing, so I tried another ignitor, nothing didn't start. So i tried putting my old one back on, nothing didn't start. I'm getting fuel, so that's off the list. So i switched the firing order and then it popped. So there's spark right? So i put it back to original firing order. Still don't start. Im thinking it's the dizzy so if anyone in the socal area, carson to be specific can let me borrow theres to see if thats the problem that would be realllllll cool.
Old Jun 24, 2005 | 09:16 AM
And when i threw code 15 the idle would surge from 1200-1500 and when i would give it a steady pedal it would hesistate or struggle. Wierd thing is now its throwing code 6, water temperature sensor
Old Jun 25, 2005 | 07:38 PM
PrettyLude's Avatar
when u swapped the ignitors did you make sure to ground them to the dizzy?
Old Jun 25, 2005 | 08:11 PM
D@nnY's Avatar
Did the car jump cam timing?
Did you check the ignition coil?
is the rotor on backwards? ( ive seen this with the ignition wires reversed to make the car run lol )
Old Jun 26, 2005 | 02:05 AM
Got the car to start again. Loose connection on the jumper harness. Made a new thread on the surging. If you can help, here's the thread https://honda-tech.com/zerothread?id=1290098
prelude2047
Nov 27, 2017 10:21 PM
Mikzize
Jan 31, 2014 07:00 AM
jdmallmotorhatch
Aug 15, 2008 11:03 PM
guymosiris
Sep 17, 2007 02:10 PM
BigDawwg6969
Oct 5, 2003 10:08 AM
