main relay question already searched
Old Jun 27, 2005 | 05:26 PM
91d15bvtec's Avatar
Default main relay question already searched PLEASE HELP
i have read almost all of the main relay questions regarding main relays in ef chassis. i can't start my car when it gets hot. i thought i was out of gas originally but after two gallons my car still won;t start. then this morning i went out and my crx started right up. then after all day in the sun not start again. also no power to pump. the main relay passed the test in the haynes manual but i have heard there are multiple tests also. also the main relay click like it should when you turn the key. no other codes or problems. i forgot to add that the solder is still in tack on the relay. it is not cracked or anything
thanks for the advise
Modified by 91d15bvtec at 6:43 PM 6/27/2005
Old Jun 27, 2005 | 06:30 PM
rainforest's Avatar
Default Re: main relay question already searched PLEASE HELP (91d15bvtec)
do yourself A favor and just resolder all the connections on the board inside the main relay it will fix it.
Old Jun 27, 2005 | 06:35 PM
Rex_Ryder's Avatar
Default Re: main relay question already searched PLEASE HELP (rainforest)
I had the same problem. I resoldered the dry socket in the main relay and that didn't appear to be the problem. I tested this by taking out the main relay and tried to start it when it was cool. The car still fires without the main relay just won't start. i hear all the clicks as it suppose to, starter, main relay when it is in, fuel pump, etc. when it is hot out it doesn't fire at all. i'm lost and need some help myself!!! i've even put in new ground wires from the battery as well as the starter. any help appreciated.
boost99
May 9, 2011 12:45 PM
ninjarich2
May 11, 2007 12:51 AM
91d15bvtec
Jun 27, 2005 06:15 PM
silentblackhat
Jun 10, 2005 07:55 PM
SouLaQuaRiuS
10
Jun 18, 2003 08:42 AM
