LS\Vtec Turbo engine problem
Old Jun 26, 2005 | 12:37 PM
canuk-sol's Avatar
Default LS\Vtec Turbo engine problem
I'm in a bit of a bind, I'm not sure whats going wrong with my motor. It burnt 1.5 litres of oil in 100 km's. All of my piston's look like they are wet with oil. I did a compression test and it came back 200-210-200-200. I figure all the oil in there is creating a better seal.
I used my b16 head that was on my b16 block, and I had no problems with it until I blew a compression ring. So I switched to a LS\Vtec for lower compression. I used a B18A block that showed no signs of scoring on any cylinders.
I used the golden eagle conversion kit, with a new head gasket that came with the kit. Also used golden eagle head stud's torqued to 72 lbs.
It does not appear as if the oil and coolant are mixing, at least there are no signs of it. The plugs are dark.
The motor doesn't smoke when idling but if I rev it up and let off the gas it smokes big time.
Any ideas of what the problem could be let me know
Thanks,
Old Jun 26, 2005 | 01:43 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: LS\Vtec Turbo engine problem (canuk-sol)
time for new rings
Old Jun 27, 2005 | 03:09 AM
canuk-sol's Avatar
Default Re: LS\Vtec Turbo engine problem (PURPLETERROR)
Wouldn't there have been sign's of cylinder scoring if the ring's were all done. When I took it for a drive the power seemed good.
Old Jun 27, 2005 | 06:35 AM
iakona's Avatar
i think the wet cylinders is your clue that the rings would be toasted in this case.
matt2320
Oct 7, 2010 05:58 AM
92HatchB16
Sep 28, 2005 12:28 PM
canuk-sol
Jun 27, 2005 09:20 AM
SilverLudeSi
May 10, 2002 01:57 PM
redman223
Mar 25, 2002 09:38 PM
