tranny help...
Old Jul 31, 2007 | 04:20 PM
ken2830's Avatar
Default tranny help...
my tranny shifts into the gears but the car doesnt move it feels like if it was in neutral...in other words i could have the car in first,start it and it doesnt stall out..i could have it in any gear and it will just rev up..the clutch depresses normal..i was thinking i need a tranny...any help would be appreciated.....
Old Aug 1, 2007 | 12:14 AM
Rd91SiB18ls's Avatar
Default Re: tranny help... (ken2830)
sounds like your diff is gone,check your axles
make sure ther in all the way.If there in it's
your tranny.good luck.
Old Aug 1, 2007 | 12:30 AM
Mista Bone's Avatar
D Tranny Guru
what year Dodge?
Chevy tranny?
Ford motor?
need a little background before I say your axle popped out.
Old Aug 1, 2007 | 11:19 AM
ken2830's Avatar
Default Re: (Mista Bone)
sorry its an h22 tranny...
Old Aug 1, 2007 | 11:33 AM
Mista Bone's Avatar
D Tranny Guru
did the speedo work correctly before?
does it still work now even though car won't move?
Old Aug 1, 2007 | 02:33 PM
ken2830's Avatar
speedo worked fine before...but I believe in any gear now it doesn't work
Old Aug 1, 2007 | 03:07 PM
ken2830's Avatar
Default Re: (ken2830)
wait I just checked it and the speedo does work....the car just won't move....
Old Aug 1, 2007 | 03:54 PM
ken2830's Avatar
false alarm problem was my right side axle pops out a lil bit from the tranny and not allowing the car to run....I popped it in it works but after a couple hundred feet it'll pop out...
Old Aug 2, 2007 | 12:42 AM
Mista Bone's Avatar
D Tranny Guru
refer to my first post........I win.
Old Aug 2, 2007 | 09:25 AM
ken2830's Avatar
LOL you do win Mista Bone.....hey do you know any site or can you give me any help in rebuilding an h-series tranny I have as a spare,I want to build it to have real short gear ratios,the same or even better than any b-series tranny.....and would that be an expensive project to do??I have the hookupz on getting my tranny worked on,I just need to find the parts I.e. gearing,synchros,and getting an aftermarket LSD and whatever I need to get those gears shorter...thanks....
Royal_C!ty
Apr 30, 2008 09:29 PM
drshottest718
Oct 6, 2006 03:22 AM
xXAtomXx
Jul 31, 2005 07:51 PM
trulyshavedintegra
Apr 6, 2005 12:59 PM
josh green
Aug 3, 2004 07:51 PM
