Speedometer Question
Old Jul 24, 2007 | 09:52 PM
firo's Avatar
Default Speedometer Question
Hi, can somebody please tell me how to fix the speedometer on my 94 honda civic, some times work's, I change one's the speed sensor in the transmision thinking that was the problem, but steel doing the same, so please help?
Old Jul 25, 2007 | 12:18 AM
Kyle R's Avatar
Default Re: Speedometer Question (firo)
Is the speedometer the only thing in the cluster that is not working?
Old Jul 25, 2007 | 06:50 PM
firo's Avatar
Default Re: Speedometer Question (herecomesboost)
yes
Old Jul 26, 2007 | 02:24 PM
slowcivic2k's Avatar
Make sure the VSS plug pins are not rusted away, they have a bad habit of doing that, they turn green or dark brown and is usually the cause of this problem. Tug them and see if they are fully seated, and not distorted.
Might also be your cluster, but I'm leaning more towards the plug being bad, or the pins simply not making contact.
Old Jul 26, 2007 | 04:52 PM
NJIN BUILDR's Avatar
Default Re: Speedometer Question (slowcivic2k)
I'm starting to have the same thing.But my AVCR mph is steady as a rock.That makes me think that the vss is ok.I'm going to pull the cluster and check/clean the plug.
xjm92x
Mar 21, 2011 09:10 PM
Civicthusiast
Feb 17, 2009 08:30 PM
SHG_James
Dec 2, 2008 09:43 PM
ek4h
Apr 15, 2007 07:49 PM
JiVe
19
Jul 22, 2003 01:12 PM
