Broken valve spring retainer - very bad??
Old Jul 29, 2007 | 08:38 PM
BoostdRex's Avatar
Default Broken valve spring retainer - very bad??
Engine: H22A
Problem: Broken valve spring retainer.
Question: Does that guarantee that somethings fucked up really bad? Will a valve fall into the cylinder if a valve spring retainer breaks? Will I have to replace the head?
I am tearing the head off tomorrow, I was just wondering if I should be on the lookout for a new head.
Any insight would be helpful.
Thanks!
Old Jul 29, 2007 | 10:52 PM
wed3k's Avatar
if the area that holds the valve lock widened up allowing the keepers to sink down it may result in physical damage to the valve.
ie: bent valve, might as well check for valve guide wear.
Old Jul 30, 2007 | 07:07 AM
BoostdRex's Avatar
Default Re: (wed3k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wed3k &raquo;</TD></TR><TR><TD CLASS="quote">if the area that holds the valve lock widened up allowing the keepers to sink down it may result in physical damage to the valve.
ie: bent valve, might as well check for valve guide wear.</TD></TR></TABLE>
Physical damage to the valve? Or to the head? I just am unsure if I am going to have to replace the head or not... I guess I will know how to describe more once I get the head pulled off...
rich7777
Feb 13, 2010 05:32 PM
superfast666
Mar 26, 2008 12:11 PM
nexgen91
Feb 20, 2007 12:25 PM
NA JDM GSR
May 25, 2006 01:01 AM
RedRacerCivic
Jul 11, 2002 12:19 AM
