d16 axle help
Old Aug 5, 2007 | 02:53 PM
fanaticalK's Avatar
Default d16 axle help
I snapped an axle at the track friday night. I'm pulling the axles out right now and there is a bit of a problem. The end of the axle is snapped off inside the tranny on the pass side.
Any help on how to get it out would be great!!!
Old Aug 5, 2007 | 03:22 PM
slowcivic2k's Avatar
Default Re: d16 axle help (fanaticalK)
You can stick a small screw driver through the other side and tap it out, but this can be tricky because the pinion shaft sits in the middle.
You could do many things to get it out, like welding a bolt to it. I would try the first method, and then pull the case apart. If you can tap it out and make sure everything comes out, the snap ring and all.
Old Aug 5, 2007 | 03:48 PM
fanaticalK's Avatar
Default Re: d16 axle help (slowcivic2k)
I've got a screw driver through the other side and I'm plowing it pretty good with a 5 lb maul hammer.............it's not moving at all.
Old Aug 5, 2007 | 04:01 PM
fanaticalK's Avatar
I used a short screwdriver and propped a 4 ft peice of 4x4 in ther and cracked it with a sledgehammer and it's out.
ralphieg
Oct 2, 2012 06:36 PM
EG93si
13
Mar 27, 2006 10:16 PM
HGZ
Mar 8, 2005 01:12 AM
Egone
Jul 17, 2003 12:23 PM
ill phil
May 15, 2003 06:27 PM
