V-AFC TUNNING TROUBLES ON A B16A BUILT
Old Aug 2, 2007 | 09:49 AM
crxrocket's Avatar
Default V-AFC TUNNING TROUBLES ON A B16A BUILT
ok here it is. i have a 91 rex w/ a jdm b16a motor. i have done a few mods to her and now i am having trouble's. so i upgraded all this to....
skunk 2 S2 valves ( std. size )
retainners
and springs
skunk 2 stage 3 cams
skunk 2 adj cam gears
225 walbro pump
AEM high flow rail
AEM regulatior
450 cc injectiors
skunk 2 pro 2 intake
dc sport header
ok now my ride don't idle for poo. and dies when you stop. my main concern is that my rev of 8200 is gone. it rev's out @ 7200 now for some reason (idk)? but wut i really dont know is how to set up all my specs on my V-AFC controller? if anyone could help me with this i would be thankful. email me at redlineracer29@insightbb.com or shot me a call @ 1-812-797-8198 ask for denny.
http://s188.photobucket.com/al...1.jpg
Modified by crxrocket at 12:21 PM 8/2/2007
http://s188.photobucket.com/al...3.jpg
Modified by crxrocket at 12:26 PM 8/2/2007
Old Aug 2, 2007 | 11:12 AM
4g hatch's Avatar
the stock ecu is set up four 240 injectors so your probably running rich. those cams are kinda big so thats why the idle is off. a apex will set the fuel ratio but thats it. u cant add or pull timing and u wont know what cam adjustments will work good unless u dyno.
Old Aug 2, 2007 | 11:20 AM
revikan's Avatar
Default Re: (4g hatch)
my bad
Old Aug 2, 2007 | 11:27 AM
crxrocket's Avatar
so how do i get my ecu fixed? i mean where and how much dose it cost fo this? better yet wut should i have done to it?
Old Aug 3, 2007 | 12:01 PM
92_civic's Avatar
Default Re: (crxrocket)
some type of stand alone engine management would work better than the vafc, what ecu are you running? try unplugging the vafc and see if your redline returns to 8100 maybe something is wired wrong,
your going to have to cut the duty cycle way down on those injectors to get it to idle well, if it were me I would look into chrome/neptune/hondata, something more "tunable" than the vafc and then make an appointment to get dyno'ed
francisco
Jul 16, 2008 08:36 PM
omg_an_ef8
Jul 6, 2006 06:40 PM
toda_eg6
Feb 23, 2005 10:03 PM
