K24/20 Help PLEASE!!!!!
Old Jul 26, 2007 | 08:36 PM
Smith bPr's Avatar
Default K24/20 Help PLEASE!!!!!
Does anyone have or no where i can get a map for the k24/20 motor with stock cams. I need one BAD to get this thing going. It idles fine and drives but is soooooooooooooo sluggish. i need a map to start from to where i may just need to +/- fuel and what not a little bit.
Please i am in deperate need to get this thing driving.
If you/they want something in return then i am willing to work it out.
Old Jul 26, 2007 | 09:21 PM
ekb16's Avatar
well u can either go onto k20a.org and find someone with the same setup as urs and ask if they will give u their map..otherwise street tune it urself and get it tuned asap b4 somethin goes wrong...thats a hybrid build u got so their isnt a base map for it
Old Jul 26, 2007 | 10:24 PM
Froth's Avatar
Default Re: (ekb16)
Try this map. I use it for my K24/20 combination and while it's not perfect it has put me into 12's on street tires. This is by no means a Dyno Tuned k24/20 map, it's actually a Partially tuned K24A2 map that I added cam angles into and subtracted a bit of fuel. My setup is K24A1/K20A2 head with some other things, Stock cams.
Check the A/F ratios and add/subtract fuel as needed. You may also need to raise the idle duty/idle RPM.
K24A1-Frank-Custom.kal Right click, save as.
-Froth
Edit: Adding disclaimer that I cannot be held liable for any damage that may result from this map, All setups are diffrent...get it Dyno tuned ASAP. It's a whole world of difference.
Old Jul 27, 2007 | 05:20 AM
Smith bPr's Avatar
thanks man. ill give it a shot.
A13sechatch
Engine Management and Tuning
Jul 26, 2009 02:48 PM
Trailz-EX
Jul 5, 2007 03:31 PM
00preludesipoop
Apr 27, 2005 01:40 PM
