Wrist pin question????? Help please
Old Aug 1, 2007 | 09:26 AM
Chris EG's Avatar
Default Wrist pin question????? Help please
I have a H22a4 from a 97 prelude. I am rebuilding the engine starting toinght. It had a slight knock. What is the chances it is a wrist pin over the rod bearing???? Also how can i tell if it is a wrist pin??????? I ve got the bearings out they dont appear to be to bad. Any advice is great
Old Aug 1, 2007 | 09:56 AM
Chris EG's Avatar
Default Re: Wrist pin question????? Help please (Chris EG)
P.s> I bought the car it wasnt running. I did compression test it was very low. Installed new oem head gasket and it fired right up but was knocking just thought this might be helpful.........
Old Aug 1, 2007 | 10:21 AM
mmuller's Avatar
Mad Scientist
to test to see is a wrist pin is nessed up you can adjust the exhaust valve tighter than spec up to the point where the cylinder wont hold compression.
if noise gets louder then thats a bad wristpin sign.
as far as rod knock, disconnect the spark plug on the cylinder that you think its making noise to see if it stops
Old Aug 1, 2007 | 10:22 AM
DonF's Avatar
Pull the plug wires one at a time. Generally if the knock goes away it is the pin, if it stays it is the bearing.
Old Aug 1, 2007 | 03:00 PM
Chris EG's Avatar
Default Re: Wrist pin question????? Help please (DonF)
See i already have the rod caps off and bearings out that was the first plan was to just replace the rod bearings. I dont wanna shoot myself in the foot if it is something else
Thanks for helping
Old Aug 1, 2007 | 04:03 PM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote">Pull the plug wires one at a time. Generally if the knock goes away it is the pin, if it stays it is the bearing.</TD></TR></TABLE>
isnt it the other way around? wouldnt piston pin knock be louder if not under load?
and the other way around with rod knock? i mean no load on bearing, less knock
Old Aug 1, 2007 | 04:34 PM
DonF's Avatar
Default Re: Wrist pin question????? Help please (mmuller)
Crap, Now I am cofused again, been awhile.The pin or piston does a "double tap" compared to the bearing. Removing the the plug wire removes that noise. A stethascope is the correct answer, piston height or crank height. I am betting on a bearing FYI.
Old Aug 1, 2007 | 06:05 PM
Chris EG's Avatar
bed time bump
Old Aug 3, 2007 | 09:24 AM
KeithsDAteg's Avatar
bump it
76 camaro car
Apr 25, 2017 03:40 AM
Myztikal
Apr 28, 2007 07:45 AM
vtecn8ive
Oct 8, 2006 03:14 PM
b18bcivic
Sep 1, 2004 07:29 PM
turboex
Aug 30, 2004 10:42 PM
