D16A6 Compression Question.
Old Jul 30, 2007 | 04:53 PM
CRX-Si-Guy's Avatar
Default D16A6 Compression Question.
What average PSI should come up when i do my compression test? Its a D16A6 out of a 90 CRX Si.
Thanks Honda-Tech
Old Jul 30, 2007 | 05:24 PM
slowcivic2k's Avatar
Default Re: D16A6 Compression Question. (CRX-Si-Guy)
The manual does not state a standard value, but 130psi is the minimum. The biggest thing to worry about is if the compression numbers are very similar to each other -/+ 28psi (IMO that is too great, if you have more than 20psi variance, you have a slight leak somewhere.)
Old Jul 30, 2007 | 05:26 PM
CRX-Si-Guy's Avatar
Default Re: D16A6 Compression Question. (slowcivic2k)
Uh oh.. Well i tested all 4 cylinders and all 4 came up equal at 75. I'm confused because i was just told that normal is 185, and minimum is 130. If thats the case, my car is done. LMK.
Old Jul 30, 2007 | 05:29 PM
Compression will vary depending on age of the engine, and how well it was maintained. 75 is very low, I'm suprised the thing fires up. I would have said around 150-160 since it is so old, that seems to be a common number I've seen with engines that old.
Make sure you are at WOT when you do this test, your results will vary greatly if you don't.
Old Jul 30, 2007 | 05:49 PM
CRX-Si-Guy's Avatar
Well, im gonna test it again tomorrow and we'll see what happens. I guess im in need of a motor bad. Im pretty sure i threw a rod bearing. I want to sell this car so bad.
WOT?
Old Jul 30, 2007 | 05:55 PM
Wide open throttle, if you are not holding the gas pedal to the floor, you are not doing it right.
stockb18c
Oct 13, 2006 08:52 AM
bgoetz
Nov 5, 2004 07:10 PM
11psiTurboSI
Apr 13, 2004 11:26 PM
98cwtypeR
Jun 4, 2003 10:29 PM
MechEng
Feb 11, 2002 06:15 PM
