Dizzy Question
I successfully put D16Z6 guts including all the wheels into a B16A distributor after the shaft bearing failed, and took the teeth off all the wheels, been working for a year and some change now, so it is doable. Just takes a really small bearing puller and a torch, but it can be done.
If your wheels are good leave them on there, other than that, the sensors are the same.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowcivic2k »</TD></TR><TR><TD CLASS="quote">I successfully put D16Z6 guts including all the wheels into a B16A distributor after the shaft bearing failed, and took the teeth off all the wheels, been working for a year and some change now, so it is doable. Just takes a really small bearing puller and a torch, but it can be done.
If your wheels are good leave them on there, other than that, the sensors are the same.</TD></TR></TABLE>
Ok thanks...i only have to change the crank sensor in the dizzy
Greyout
32
Apr 6, 2005 08:34 PM
bulldog_RS20
21
May 7, 2002 01:20 PM
